Sloping Floor - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-05-2009, 08:10 PM   #1
Sloping floor
All, I am installing peninsula cabinets. The problem is the 1 1/2 inch slope in 111" span. If I float it I will have to taper back to meet the rest of the house and two of the angles would be extreme. I was going to do a small raised pour to bring the new cabinets to level but not to sure how it would look. Also thought about ripping 4x4 down to avoid having to use 1 1/2 inches worth of shims... Any suggestions?
Thanks,
EZDYS2009
EZDYS2009 is offline   Reply With Quote
Old 05-05-2009, 09:15 PM   #2
timthetoolman
wow that is a pretty un-level floor you got there! I would rip down two 2X4's that are 111 inches from 0 to 1 1/2" and make a frame with cross pieces every couple feet. I wouldn't use shims on cabinets to raise 1 1/2". When you go to cut the shims, trust me they would never stay in. They do make toe kick for the bottom that is wider than average to cover the gap.
timthetoolman is offline   Reply With Quote
Old 05-06-2009, 12:33 AM   #3
Thanks, I was ready to get the mud and wire and go for the new retro look.
ezdys2009
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Floor is sloping to outside edges Livestrg05 Building & Construction 2 04-01-2009 08:15 AM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Laying "new" wood floor next to sloping old floor troyce1 Flooring 25 10-16-2008 01:34 PM
Installing porcelain tile on a sloping floor Wanttodoitright Flooring 11 03-20-2008 01:37 PM
