Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-24-2008, 08:08 AM   #1
Sloped Bathroom ceiling
Howdy folks,
I'm re-building a half-bath in the upper level of a house with a 12/12 pitch roof, adding a bath tub. Due to plumbing and structural conserns, the tub will have to be situated along the knee walls, with the ceiling sloping from 4' to 8' above it. The ceiing is presently drywall, and the room has a very strong exhaust fan at floor level venting out of the house (not the unfinished attic space.)
With the ceiling being so close to the tub, I would think it will get some steam contact. Of course I'd love to not re-do the ceiling and just paint the heck out of it, but suspect I might run into some problems long term.
Anyone have some advice?
DSKUP is offline   Reply With Quote
Old 12-25-2008, 12:16 AM   #2
Drywall contractor
With proper ventilation and bath "appropriate" paint you shouldn't have issues just from humidity/steam. If you are truly concerned, you could put up backer board and tile it......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 12-25-2008, 01:03 AM   #3
K&B Remodeler/Tile Guy
angus242's Avatar
Why is there an exhaust fan at floor level? If the exhaust fan was near the peak of the ceiling, you'd be good to go. That's where the steam/moisture will rise to.
Angus
angus242 is offline   Reply With Quote
Old 12-27-2008, 08:08 AM   #4
Thanks for the replies. The fan is floor level because the vent duct runs down a crawl space behind the knee boards and out the gabel wall of the house. I could put a vent on the ceiling, but I would then have to do some roof work... which isn't particularly fun on the 12/12 pitch. But of course I can do it if necessary.
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 07:07 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Bathroom Ceiling above shower qvminich Building & Construction 13 11-07-2008 03:40 PM
Best way to texture a bathroom ceiling DIY-Renovator Painting 3 07-30-2008 10:49 AM
excessive moisture on bathroom ceiling Den69RS96 General Discussion 8 01-14-2008 09:37 AM
