Sliding Door - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-05-2013, 03:46 PM   #1
analogmusicman's Avatar
Rewards Points: 560
sliding door
i just finished (almost) an insttallation of sliding doors in my pantry. the left door won't stay closed. (creeps an inch open). any ideas how to keep it closed?
tnx,
analogmusicman is offline   Reply With Quote
Old 10-05-2013, 03:57 PM   #2
kwikfishron's Avatar
Rewards Points: 176
Are you sure the track level and true?
kwikfishron is online now   Reply With Quote
Old 10-05-2013, 06:17 PM   #3
Rewards Points: 560
just about as "level and true" as possible! (I'd say the bubble in my level is probably within 1/128 th of being dead center.) anyway,you'd think that either door would start to creep when partially open if track levelling were the problem.
I'd like to think that a company which makes "good stuff" like Johnson would build in enough drag into the rollers so that this wouldn't happen.
tnx,
Old 10-05-2013, 07:02 PM   #4
Rewards Points: 13,260
Know how to check a level to see how accurate it is?
Just turn it around to see if you get the same reading.
I hardly think any company's going to have built in drag to offset someone not taking the time to set the header level.
Old 10-05-2013, 10:41 PM   #5
Rewards Points: 560
Originally Posted by joecaption View Post
know how to check a level to see how accurate it is?
what?!
Salvage or replace rotting sliding door sill? BubbaJoeToolbox Building & Construction 16 09-12-2013 05:53 PM
Simonton Sliding Patio Door Removal mrdave100 Windows and Doors 1 07-07-2013 09:28 AM
Installing door jamb for sliding surface mount door edspyhill09 General DIY Discussions 2 06-24-2013 07:02 AM
60" Sliding Door Installation in Load Bearing Exterior Wall kirbz Building & Construction 8 05-09-2013 05:17 PM
