Slate Under Cabinets? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-08-2010, 04:42 PM   #1
CCP
Slate under cabinets?
I am in the process of finishing my basement. I have a wet bar area planned with a row of cabinets and an under the counter beverage cooler. I have some slate tile that I am going to install in that area of the basement. I am worried about being able to install the cabinets level on the slate. This is due to the unevenness surface of the tile. Should I plan on putting the slate under the cabinets? Due to the beverage cooler I need something under cabinets so they are at the same level at the rest of the floor. Could I put something else under the cabinets and tile to the front of the cabinets with the slate?
Thanks!
CCP is offline   Reply With Quote
Old 03-08-2010, 11:23 PM   #2
firehawkmph's Avatar
Rewards Points: 1,798
The uneveness of the slate shouldn't stop you from installing the cabinets on it. That's what they make shims for. However, if the slate is pretty rough, you may have to use a small trim around the toekicks and any exposed sides. If you wanted to tile around them, then it wouldn't hurt to put some plywood underneath. I would use plywood that is slightly thinner than the average thickness of the tile so it wouldn't show after the tile is in.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-09-2010, 04:57 PM   #3
CCP
Thanks for your help. I have shimmed cabinets before but this slate is a little more intimitating.
Kitchen cabinets - Are Ikea cabinets good? What other mfgs have you used? whataboutj Kitchen & Bath Remodeling 24 11-09-2012 07:14 PM
Plasma TV over Slate jrcrum Home Theater 8 12-16-2009 05:59 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-21-2008 12:32 AM
How are the premade HD and Lowes Cabinets? twilightcall Carpentry 10 05-25-2008 11:23 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
