Skim Coating Wood Panel Disaster - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-09-2009, 06:29 PM   #1
Skim coating wood panel disaster
Hey guys, I'm new to the boards and need some advice on my living room. About a year ago we hired a contractor "friend" to help us remodel our home, there was a living room full of wood paneling at the time. He suggested instead of putting in drywall a cheaper way of getting the same effect would be skim coating it with some sort of plaster-mud type substance.
Not a good idea in south Louisiana! After a few months it bubbled up and eventually started to peel off of the paneling. It looks horrible. I am wondering if its possible to peel away the rest of the plaster in the room and just paint the paneling, but it has been sanded and I'm not sure how that would look. Any advice would be great, thanks!
krislb is offline   Reply With Quote
Old 09-10-2009, 01:09 AM   #2
Registered User
Termite's Avatar
Possible? Sure. Will it look good when you're done? Probably not.
Shame on that guy for even suggesting that a skim coat of mud would hold up over paneling. Jeez.
The prep work that you'd have in getting that paneling back to paintable shape would be considerable...And in the end you'd have painted paneling...Not a desirable feature! I think you'd be time and money ahead to just remove the paneling and the mud all at once and trash it. Re-install paneling if you like, or sheetrock the walls which sounds like it was the look you were after in the first place. Neither sheetrock or paneling are expensive, and both can be DIY jobs with the proper research ahead of time. There are some great online video tutorials on sheetrock installation and finishing on youtube, and we're happy to help here as well.
Old 09-10-2009, 10:29 AM   #3
Thanks for the response. I was hoping for an easy fix but it looks like I'll be tearing down the paneling too.
Old 09-11-2009, 10:55 AM   #4
Sephora's Avatar
Rewards Points: 150
We painted over our wood panel and it looks great. But we never put mud over it.
I hope you work it out!
Sephora is offline   Reply With Quote
Old 09-12-2009, 12:13 PM   #5
Drywall contractor
Rewards Points: 1,070
Joint compound is not intended for use on wood. You could put a layer of drywall over the paneling. Pull the base, hang 1/4" drywall over the paneling. Butt to the door and window trim and flat tape any gaps. Install new base. Or do the teat out and hang 1/2". That would allow you to access inside the walls to update/add electrical, plumbing, etc........
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Tags
drywall , skim coating , wood paneling
How long after skim coating... 2600truman Building & Construction 10 07-21-2009 10:20 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 04:29 PM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
Replacing Wood Panel 4'x8' Siding Chevmann99 General DIY Discussions 5 10-02-2005 08:43 PM
