Skim Coat For Damaged Plaster Walls - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-13-2007, 07:51 AM   #1
Skim coat for damaged plaster walls
The plaster ceiling of my 1930 bathroom was damaged by moisture. I scraped the ceiling and walls. In some areas, the multiple layers of old paint peeled off easily in large sheets, revealing the hard, smooth finish plaster underneath. In other areas, the oldest layer of original oil-based paint is strongly adhered like a hard ceramic glaze. Even aggressive paint stripper is painfully slow to soften it. Also, I left some gouges in the plaster, trying to get the old paint off.
Rather than struggling for days to get every speck of old paint off, can I just skim coat the whole plaster surface with joint compound and sand it smooth? (This is a 5' x 7' bathroom. Subtracting tiled area on four walls, the door, and the window, the plaster wall area is only a few square feet.) The plaster on the walls is flat and solid; it's only a couple of layers of old paint and the gouges I made which leave it superficially uneven.
On the ceiling, the finish plaster fell off in a couple of moisture-damaged areas, leaving the rough brown coat exposed. Finish plaster thickness is about 1/16". Same question here -- can I fill in the missing finish plaster with a hot mud, then skim coat the whole ceiling and sand it?
Finally, there's about a one-inch radius where the walls meet the ceiling. It has damage to the plaster on a couple of linear feet. I can't figure out what tools to use, to repair and blend in this radiused corner.
Thanks for this great site; the search function is like an encyclopedia.
slapdash is offline   Reply With Quote
Old 10-13-2007, 08:14 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Have you considered "overlaying" it with 3/8" sheetrock and 2" screws? Much easier and also a permanent correction to the ceiling.
FWIW: We do these all the time for poor looking old plaster ceilings. In fact, ceilings we did over 20 years ago, still look new...
- Build Well -
Old 10-13-2007, 09:15 AM   #3
Yes, I am considering to overlay the ceiling with sheetrock. I saw your photo of one in another thread.
I would prefer to keep the plaster walls, since they interface with tile edges and the door casing. Is it an unreasonable amount of work to skim coat and sand the limited wall area that would be left (about 20 sq ft)?
In any case, there's still that 1-inch radius all around the perimeter of the ceiling.
Old 10-13-2007, 06:05 PM   #4
MyDIYTry
We skim coated our entire living room and ceiling. We also have plaster walls, but the previous owners did a horrible job painting. The texture was bad, there was dried thick spots and drips, so we skim coated. We also had to repair a crack in the wall.
It's a pain in the neck for a large room, but a bathroom might not be that bad. When you sand, be prepared for extremely fine dust. It's hard to clean up, so I recommend laying plastic or some non-porous sheet down.
www.mydiytry.com
MyDIYTry is offline   Reply With Quote
Old 10-14-2007, 06:27 AM   #5
Okay, thanks for the info, MyDIYTry.
waterproof plaster shower walls carsokk Remodeling 2 01-31-2008 09:14 AM
Plaster walls and Lathe Keith in Connecticut Remodeling 5 01-03-2008 08:36 PM
finish coat over painted walls a_theater_god Remodeling 2 07-30-2006 11:27 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
ARCHWAYS in PLASTER WALLS tmacwith Remodeling 2 03-05-2006 09:24 PM
