Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 06-15-2007, 04:51 PM   #1
weekend warrior
siding, soffits, gutters - order?
I have vinyl siding, soffits, and gutters to be done.
In what order should these jobs be done?
I believe most siders do the soffits as well, correct? Right now I have bare 2x6 as fascia. I'm still unsure if I need to put wood over this, or just flash it with metal/plastic and apply a gutter over it?
johnny331 is offline   Reply With Quote
Old 06-15-2007, 05:11 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Install:
Before: Wrapping of all wood trim work with aluminum that will not be replaced with vinyl. That includes Wrapping the fascia with aluminum.
Then:
1.) Vinyl Soffits
2.) Vinyl siding
3.) Gutters
Yes.
If you are installing vinyl siding and aluminum trim, then the 2x6 is fine.
Fascias are wrapped in aluminum. Soffits are vinyl. Vinyl installers usually include aluminum wrapping of areas in their estimate. Gutters are installed over the aluminum wrapped fascia. Brackets are installed and downspouts connected last.
- Build Well -
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
Vinyl Siding Wolf&Weyana Building & Construction 1 08-30-2006 10:25 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
