Siding Removal - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-05-2013, 12:24 PM   #1
Solutions (handyman)
Rewards Points: 362
Siding removal
Quick question. I am re-siding an 800 sq. ft. cottage with vinyl siding and plan to remove the existing wood siding. (Could go on top but I don't like the idea or results). My question is general for the removal. Charge by hour or by sq. ft. ? What is a fair formula?
Thanks.
Mark Harvey is offline   Reply With Quote
Old 01-05-2013, 12:32 PM   #2
Rewards Points: 13,228
Since you have no idea on how it was fastened or how hard it will be to removed I'd do it by the hour to be safe.
But I also would have just gone over what's already there unless it's water damaged or I was planing on insulating or rewiring while it was open.
Old 01-07-2013, 03:01 PM   #3
Rewards Points: 362
insulation under retro siding
If I were to go over existing siding, I would add some insulation between old and new. I've heard about the foil bubble wrap type but also tend towards the plastifab (solid type) insulation. Suggestions? As to wiring, internal insulation etc. the ball is in the owners court at this time.
Screw holes in vinyl siding piece due to awning removal - fill or replace? mark2741 Building & Construction 9 03-24-2011 01:21 AM
Asbestos siding removal Dave4788 General DIY Discussions 6 04-22-2009 04:53 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
