Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 07-07-2004, 09:45 PM   #1
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Default Siding: Cement Vs. Cedar
Siding: Cedar vs. Cement
Cedar and Fibercement (Cement) siding are both high end materials. Either Cedar or Cement sidings require a slightly greater upfront investment over vinyl or aluminum; however the result is products that will last much longer.
Cedar siding is wood, from the Cedar tree. Cedar is one of the most durable of woods. Cement siding is made of a mixture of cement and cellulose. Cellulose is the fiber in Fiber cement. Cellulose is basically wood fibers. Either Cedar or Cement will be very strong and durable. Both are resistant to impact damage from hail or tree damage.
In an unfinished state cedar siding will last longer than cement siding. It is highly recommended to stain either cedar or cement siding for the longest lasting installation. In it’s painted or stained state, Cement siding is rated to last much longer than cedar siding.
Both Cedar and Cement siding are available pre-finished. Cedar siding can be bought with a 15-year color warranty while Cement siding can be bought with a 15-year or 25-year color warranty. Usually these sidings can be stained by the factory with major manufacturers of stain like Cabot and Olympic.
Cement is more difficult to work with from an installation point of view. Special tools are required to cut cement siding and cement siding is very tough to hand nail. Cement kicks up an extreme amount of dust when cutting so special respirators are sometimes required when cutting cement siding.
Cedar is an attractive material to bees and other insects while cement is very insect resistant. Cedar can warp after years of prolonged UV exposure from the sun. This is due to heat and is most common on the east and west sides of the building. Cedar typically has a more attractive and unique grain pattern. Cement siding usually is more uniform and the lengths of the boards are usually of equal length. Cedar lengths usually vary in length.
www.reliableamerican.us
-Grumpy
Chicago Roofing Chicago Gutters
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain saftey! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 11-14-2004, 10:39 PM   #2
Question Hardi siding questions
Grumpy,
Installed 9 1/4" hardi siding (8" exposure) last Friday. The yard that supplied the material lent us a electric shear. What a beautiful tool. No mess, no dust, and pretty accurate cuts. I loved the Hardi-siding as well. Here's my question. We blind nailed each piece using a Bostitch siding gun which made it very easy. Is it common to have to face nail the bottom edge? Some area's seemed somewhat loose. Secondly, if we face nail the bottom as well as blind nail the top, will the acrylic paint cover the nails well? It looks great blind nailed, but I don't trust the 8" face to stay tight. I've been reading your posts and you seem to have the experience we need. Also, you discuss using prefinished siding and then getting the paint and caulk match from the company that applies the paint. Will that paint adhere to the galvanized nails reasonably well? Eagerly awaiting your answers as we have to finish a second side on Tuesday. Thanks in advance. Retiree.
retiree is offline   Reply With Quote
Old 11-15-2004, 10:39 PM   #3
Grumpy's Avatar
At 8" siding you may have to occasionally face nail. 6" is typical and blind nailing usually is good enough. I prefer blind nailing.
Take some of the extra stain and touch up the nail heads. I assume you have some prefinished siding?
They paint should have no problem adhering to the nail head. Infact the paint is not paint at all. It is SOLID STAIN. You can even sometimes get the nails prefinished.
-Grumpy
Old 11-16-2004, 12:58 PM   #4
Default Hardi siding
Thanks for your quick reply.
Didn't use prefinished on this job (primed only), but have to help my son-in-law do his farmhouse next year down in Chapel Hill, NC.
Checked the price of cedar - $2.90 per foot.(heart attack city)
The Hardi was $7.80 per 12 ft. - Not bad at all. How much more expensive is the pre-finished?
The shear was definitely the way to go, as was the siding gun.
I normally use the Fine Homebuilding magazine forum. I love that magazine, even the ads are good. The forum is good and very easy to navigate. I found this one by typing in "Hardi Siding Forums".
Thanks again for your expertise, retiree(Mike Flynn)
Old 11-20-2004, 01:14 AM   #5
8-1/4" x 12' Hardiplank w/woodgrain is $4.49 in Charlotte, NC area. Just looked at it at Lowe's over the weekend - just thought you might like to know...
Neil_K is offline   Reply With Quote
Old 03-19-2005, 03:07 PM   #6
aka:awesomedell
Send a message via MSN to housedocs
Another great thread Grumpy, posting just to bump it to the top. Really need to make it a sticky or better yet put a copy in the DIY Guides. Great info for diyers, just the facts without the hard sell! BTW You have great websites and great name recognition. Search Chicago and any one of several terms and boom there you are! Hat's off!
All you need is ignorance and confidence and success is assured. - Mark Twain
housedocs is offline   Reply With Quote
More On This Topic
Cellulose insulation is an eco-friendly form of home insulation that's made from plant fibers. Like the more common fiberglass insulation, it can be inserted between walls and into roofs to keep homes warm during the winter and cool in the summer. Unlike... Read More »
Hi, this is Jeff Wilkins on behalf of Expert Village. So, try to be careful not to crowd the hook eye. Now, we're ready to finish the fly off. We're going to do a whip finish. Take care to come around the hook eye. Be careful not to trap any fibers. You... Read More »
Fiber cement fascia boards provide the same water protection as other materials but offer increased options for finishes. Since fiber cement tends to be more expensive than other types of fascia, you need to take greater care when you install it. Read More »
A cedar chest is an attractive decoration for any room, but requires special maintenance to keep it that looking its best. Antique cedar chests, in particular, should be treated with special attention. With the proper care, you can enjoy your cedar chest... Read More »
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 06:24 PM
revitalizing cedar siding Fat b Painting 1 04-30-2007 03:29 AM
Siding Options Vinyl vs. Fiber Cement obrien11j Building & Construction 4 08-20-2006 04:44 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 02:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 05:35 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
