Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 07-07-2004, 09:45 PM   #1
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Default Siding: Aluminum vs. Vinyl
As a contractor who installs siding, I am asked quite often “What is the difference between vinyl and aluminum siding?”
Vinyl siding is an extruded plastic material. It usually ranges in thickness from .040” - .046”. Aluminum siding is a formed material, typically .019” thick. Vinyl siding has a solid color, while aluminum siding has a baked on enamel paint finish.
Vinyl siding is typically more durable than aluminum being that it is over twice the thickness. Vinyl siding does become slightly brittle during the winter time. Aluminum siding maintains the same properties year round despite the temperature. Vinyl siding also expands and contracts in greater fluctuation than aluminum siding.
As mentioned before vinyl siding has solid color, meaning even if scratched the color won’t change. Aluminum siding has the baked on enamel finish, if scratched the paint will be removed and the bare metal below will be visible. However due to the expansive properties of vinyl, aluminum siding takes paint better if you ever decide to re-paint. It is not recommended to paint vinyl.
Aluminum siding has lost tremendous market share since the release of vinyl siding. Some statistics report as much as 80% of all sidings installed are vinyl. Aluminum siding is still very common for trim pieces because of its flexible properties. It is very easy to custom bend an aluminum trim piece. All vinyl has to be extruded or molded into shape.
In most situations it is recommended to install vinyl siding with aluminum trim pieces. Overall vinyl is more durable, has solid color and is cheaper than aluminum.
www.reliableamerican.us
-Grumpy
Chicago Roofing Chicago Gutters
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain saftey! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 03-19-2005, 02:55 PM   #2
aka:awesomedell
Send a message via MSN to housedocs
Pretty good informative piece Grumpy, my compliments sir! Also thought it would be a good time to give this a bump, spring is here and home improvement fever will be catching soon.
All you need is ignorance and confidence and success is assured. - Mark Twain
housedocs is offline   Reply With Quote
More On This Topic
Over time, the exterior of houses will need general maintenance, including painting. The exterior of the house includes siding, trim, deck work, fences and brick foundations. Because these areas are all exposed to the weather, you will need to select... Read More »
Water damage can cause all kinds of problems for your home, but you can help prevent it if you buy the right type of fascia. While all types of fascia can function equally well, maintenance and cosmetic differences can help guide your decision. Read More »
Clay Pottery Extruder Tips
Clay Pottery Extruder Tips by Expert Village
So now I'm going to tell you a little bit about the extruder. This right here is my extruder and the way that it works you put clay on the top, this holder right here hooks on to the bottom and it holds the die that you are going to use for extrusion. A... Read More »
A small hole in a wall is an unsightly nuisance. If the hole is less than 3 inches in diameter, you can easily repair it with an aluminum patch kit. Repair kits typically come with a 4-by-4 inch adhesive aluminum patch, spackling compound, sandpaper and... Read More »
This is John Mendez with Expert Village and we are going to use some pigment with our resin and hardener polymer to make it into and enamel. And I have chosen a pigment that is used for lots of different purposes. You can add this to paint, you can add... Read More »
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 06:24 PM
Vinyl Siding Estimate tmacwith Building & Construction 6 05-01-2007 11:40 PM
Vinyl siding over wood clapboard C&D Building & Construction 3 09-13-2006 11:14 PM
Vinyl Siding & windows question blazermaniac General Discussion 6 04-08-2006 02:47 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 05:35 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
