| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Select Exterior Paint
by eHow.com
Over time, the exterior of houses will need general maintenance, including painting. The exterior of the house includes siding, trim, deck work, fences and brick foundations. Because these areas are all exposed to the weather, you will need to select... Read More »
How to Buy the Right Type Fascia
by eHow.com
Water damage can cause all kinds of problems for your home, but you can help prevent it if you buy the right type of fascia. While all types of fascia can function equally well, maintenance and cosmetic differences can help guide your decision. Read More »
Using Pigment When Making Jewelry
by Expert Village
This is John Mendez with Expert Village and we are going to use some pigment with our resin and hardener polymer to make it into and enamel. And I have chosen a pigment that is used for lots of different purposes. You can add this to paint, you can add... Read More »
How to Enamel a Clay Sculpture
by Expert Village
We are going to now that it's almost dry. We are going to use the crystal clear enamel in order to reinforce the figurine. This is going to give us extra strength. It's very good, only one coating it's enough and it prepares the figurine to be painted... Read More »
Clay Pottery Extruder Tips
by Expert Village
So now I'm going to tell you a little bit about the extruder. This right here is my extruder and the way that it works you put clay on the top, this holder right here hooks on to the bottom and it holds the die that you are going to use for extrusion. A... Read More »
