Shower Rod On Sloped Ceiling - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-05-2008, 11:07 AM   #1
sji
Shower Rod on Sloped Ceiling
We are nearing completion of a bathroom remodel and I've run into an issue with the bathtub regarding hanging a shower curtain rod. The tub is in an alcove with an angled ceiling in the back due to an eave. The angled section meets the back wall at a height of about 5'6". I'm trying to figure out a solution to hanging a shower curtain rod - if I put is where the wall is straight, it would be too low. If I raise it and attached 1 end to the angled wall, then the curtain wont cover the last foot of the shower . Does anyone have any suggestions for how to mount a shower curtain rod when part of the ceiling is angled? Are there brackets to accomadate mounting on an angle, and how can I deal with the open part on the end?
THanks
sji is offline   Reply With Quote
Old 06-06-2008, 03:14 PM   #2
47_47's Avatar
Rewards Points: 44
Maybe you could install a fixed shower panel for the last foot and have your curtain underlap that.
47_47 is offline   Reply With Quote
Old 06-08-2008, 07:00 PM   #3
Remodeler
i ran into this one time. We ended up using a wire system used to hang curtains. I think we got it at IKEA. We used a corner piece at the angle to make the wire follow the ceiling.
http://www.ikea.com/us/en/catalog/products/60075295
might work.
-Dan
JenkinsHB is offline   Reply With Quote
Old 03-04-2009, 01:30 AM   #4
CCH
any luck
sji - Didi you have any luck with the curtain rod. I am in the same situation and want to figure out what to do before tiling.
CCH is offline   Reply With Quote
Old 03-20-2009, 03:46 PM   #5
Had the same problem with our 1940's second floor bathroom. Our contractor suggested building a 1-2 foot wall along the tub and up to where the slant of the wall meets the celing. This "squares" thing up, while still giving you plenty of room to install a shower curtain, and access to the tub.
allenewilborn is offline   Reply With Quote
Old 03-31-2009, 03:43 PM   #6
Lightbulb
Angled Ceiling.. shower rod
I just tried to figure this out myself. I ended up buying a "deck hinge" and "end cap eye" from a marine supply place. They use them to attach railings or canopies. I cost me $9 for both pieces. You might also find the same sort of thing for awnings.
If I knew how to attach a picture I would.
Good Luck!
Steve
Mustbecrazy is offline   Reply With Quote
Old 08-16-2009, 01:46 PM   #7
DCA
Specialty brackets for similar purpose
Hello,
I was searching for hardware to hang a clothes rod from the ceiling and came across this hardware, perhaps it can help someone...
http://abrechtbracket.com/CeilingRod.html
DCA is offline   Reply With Quote
Old 08-17-2009, 06:09 PM   #8
Renovation Contractor
Paragon's Avatar
Rewards Points: 150
DCA, others and future inquiring minds. I have a rendering on my website that might help visualize the solution with a stub wall.
http://paragonrenovations.net/renderings.aspx
This is a project that I will be kicking off within the next month or so but if you go to the link I provided it will bring you to my website and some of my project renderings. Scroll down to the third video and you will be able to watch this rendering and will see the stub wall come in at 2:06. Hopefully this helps envision the wall.
If you have any other questions please don't hesitate to ask!
Good luck all, be safe!
James D. Van Raden
Owner, Paragon Renovations Moorhead, MN/ Fargo, ND
"Committed to providing the finest renovation services available"
Paragon is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 01:05 PM
building a shower ceiling in a non-perfect situation homealone Remodeling 10 06-02-2008 07:55 PM
Hardibacker on shower ceiling? sharisavage Remodeling 6 10-06-2005 12:40 PM
