Shower Pan- Pre Slope - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 02:20 PM   #1
Rewards Points: 29
Hi all,
Have completed the pre slope on a shower pan and noticed a few areas where the concrete has sunk dis-proproportionately to other areas, creating some low spots on my slope from curb to drain.
Some of these low spots are around 1/16" deep over a 3-4" area.
should I
  1. skim coat the pre slope to correct the sunken spots
  2. remove pan and start over
  3. do nothing and move to the liner stage and flood test?
Paul
Paul8434 is offline   Reply With Quote
Old 05-25-2011, 06:34 PM   #2
DIY staff
Rewards Points: 7,174
That pre slope is fine---as a matter of fact it's the finest job I've ever seen--
It's time for you to add your liner and pack the base.--Good work.---Mike---
Old 05-25-2011, 06:38 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You are in great shape. The liner will conform to any small variance that exists and the second cement cast will see to it. Keep going...excellent looking job from here. It's almost a shame to bury that one out of sight.
XXX
Old 05-25-2011, 06:39 PM   #4
Rewards Points: 29
Mike, Bud,
Thanks for the compliment.
I have used Mike's advice from my previous posts to get me to this stage.
Onward to the flood stage.
Paul
Old 05-25-2011, 06:42 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Don't forget to use a little sealer on top of that flange and under the pan liner.
XXX
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
creating new shower floor/ slope??? Bob Funk Plumbing 2 03-01-2010 05:22 PM
Pre slope question on shower floor - did I do it wrong? maestro300 Flooring 2 02-20-2009 03:44 AM
shower pan slope 2picky Remodeling 3 11-15-2008 05:05 PM
Shower floor slope Not Sure Building & Construction 11 06-10-2008 12:12 PM
