Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-25-2011, 02:22 PM   #1
Shower Pan- Flood Test- Drain Plug
Does anyone know of a suitable device to use as a drain plug for a flood test of the drain liner?
(i suspect the plug is very simple, but do not want to mess up this stage)
Paul
Paul8434 is offline   Reply With Quote
Old 05-25-2011, 06:24 PM   #2
Super Moderator
They are called 'test plugs' and are in the same section as the Fernco rubber fittings.
It's a soft rubber disk with a steel washer on either side--a bolt and wing nut through the center.
Tighten the nut and that squashes the rubber--expanding it it stop up the pipe.
Old 05-25-2011, 06:35 PM   #3
Tileguy
Bud Cline's Avatar
There is also an inflatable rubber bulb available.
Old 05-31-2011, 10:57 AM   #4
www.No-Curb.com
JohnFRWhipple's Avatar
This is a picture of a 2" twist and set plug. Adjust the wing nut until it goes into your drains piping with a tiny bit of pressure and twist it down until you have a good seal. Do not over tighten or apply to much pressure to the drain.
This an inflatable test plug with a 3' extension. I use either my bike pump or mini compressor to inflate.
JohnFRWhipple is offline   Reply With Quote
Old 05-31-2011, 11:01 AM   #5
www.No-Curb.com
Some more options for your flood test. If you need help sourcing a plug here in Vancouver give me a call and I can point you in the right direction.
Old 05-31-2011, 09:23 PM   #6
Thanks John,
Sure gave me a clear idea of the different options.
I did struggle to find a drain plug as all they sold at two local home improvement stores was 2" drain plugs.
My scenario required me to taper my drainset to match with 1.5" from the previous installer.
After racking my brain i went for the simple drain plugs that are common for laundry sinks etc.
I figured if the test passed then i was alright. If the test failed then i would really have to hunt to find the right drain plug to rule out a poor seal.
Paul
The Following User Says Thank You to Paul8434 For This Useful Post:
oh'mike (05-31-2011)
Old 05-31-2011, 09:40 PM   #7
Tileguy
Bud Cline's Avatar
Drain plugs = Plumbing Supply.
Old 06-01-2011, 10:18 AM   #8
www.No-Curb.com
The long thin plugs I have are designed to slip past the 2" mouth of a drain's body and into the 1 1/2" pipe. A few pumps and you have a tight seal.
Like Bud suggests a plumbing wholesaler in your town or online will be your best source. Many large "Box Retailers" I have found do not sell any plugs for testing showers.
How long do you plan to flood your shower for? Do you know how to measure for leaks and evaporation?
JW
Old 06-01-2011, 11:35 AM   #9
Hi John,
I think calling someone like Hillcrest (or another plumbing supplier) locally would have been prudent.
My test consisted of pushing a laundry sink into the 1.5" drain and fiddling to ensure a tight seal.
I used about 3 " of water and noted the height on two walls.
I waited 24 hours.
I noted no difference in height after 24 hours.
I did not notice any evaporation loss or leakage.
After draining the pan i then went under the crawlspace to inspect the plywood base and joists and noted no moisure or wetness.
I note your comments on measuring for leakage and evaporation.
Can you elaborate?
I have enclosed a pic of of the status of my job so far. But am not adverse to going back and re-testing.
Paul
Old 06-01-2011, 07:27 PM   #10
Super Moderator
Looking very fine--keep the pictures coming.
Old 06-01-2011, 08:29 PM   #11
Tileguy
Bud Cline's Avatar
Why is that little piece of duct tape on the pan liner? The one near the bottom.
Old 06-01-2011, 10:09 PM   #12
Hi Bud,
Good eye. That was used as one of my markers to note the water level during the flood test.
Paul
Bud Cline (06-02-2011)
Old 06-02-2011, 10:01 AM   #13
www.No-Curb.com
On an extended flood test with hot job site conditions or excessive air movement you need to measure the rate of evaporation.
We set up a second dish of water. Something like a casserole pan and fill with a inch or so of water. We add a stack of coins to both the casserole pan and shower pan. Both will evaporate at the same rate.
By using coins you can see exactly if the pan is leaking and by what rate.
I just noticed your in Vancouver. Call me when you do your next shower and I will lend you a plug.
JW
Old 06-02-2011, 04:07 PM   #14
Tileguy
Bud Cline's Avatar
Jheeeeezh!
You guys in Canada don't have a ruler or a yardstick or a tape-measure device?
Old 06-02-2011, 04:19 PM   #15
www.No-Curb.com
Originally Posted by Bud Cline View Post
Jheeeeezh!
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
1 1/2" shower drain tlynn Plumbing 3 02-25-2010 06:09 PM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Fleible drain hose for shower? devouru Plumbing 1 06-25-2008 11:06 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
