-   -   Shower Pan- Flood Test- Drain Plug (http://www.diychatroom.com/f15/shower-pan-flood-test-drain-plug-105560/)
Paul8434 05-25-2011 01:22 PM
Does anyone know of a suitable device to use as a drain plug for a flood test of the drain liner?
(i suspect the plug is very simple, but do not want to mess up this stage)
Paul
oh'mike 05-25-2011 05:24 PM
They are called 'test plugs' and are in the same section as the Fernco rubber fittings.
It's a soft rubber disk with a steel washer on either side--a bolt and wing nut through the center.
Tighten the nut and that squashes the rubber--expanding it it stop up the pipe.
Bud Cline 05-25-2011 05:35 PM
There is also an inflatable rubber bulb available.:)
JohnFRWhipple 05-31-2011 09:57 AM
Flood Testing Procedures
http://i839.photobucket.com/albums/z...ouversales.jpg
This is a picture of a 2" twist and set plug. Adjust the wing nut until it goes into your drains piping with a tiny bit of pressure and twist it down until you have a good seal. Do not over tighten or apply to much pressure to the drain.
http://i839.photobucket.com/albums/z...nVancouver.jpg
This an inflatable test plug with a 3' extension. I use either my bike pump or mini compressor to inflate.
JohnFRWhipple 05-31-2011 10:01 AM
More options
1 Attachment(s)
Some more options for your flood test. If you need help sourcing a plug here in Vancouver give me a call and I can point you in the right direction.
Paul8434 05-31-2011 08:23 PM
Thanks John,
Sure gave me a clear idea of the different options.
I did struggle to find a drain plug as all they sold at two local home improvement stores was 2" drain plugs.
My scenario required me to taper my drainset to match with 1.5" from the previous installer.
After racking my brain i went for the simple drain plugs that are common for laundry sinks etc.
I figured if the test passed then i was alright. If the test failed then i would really have to hunt to find the right drain plug to rule out a poor seal.
Paul
Bud Cline 05-31-2011 08:40 PM
Drain plugs = Plumbing Supply.
:yes:
JohnFRWhipple 06-01-2011 09:18 AM
Flood Testing your own shower pan
The long thin plugs I have are designed to slip past the 2" mouth of a drain's body and into the 1 1/2" pipe. A few pumps and you have a tight seal.
Like Bud suggests a plumbing wholesaler in your town or online will be your best source. Many large "Box Retailers" I have found do not sell any plugs for testing showers.
How long do you plan to flood your shower for? Do you know how to measure for leaks and evaporation?
JW
Paul8434 06-01-2011 10:35 AM
1 Attachment(s)
Hi John,
I think calling someone like Hillcrest (or another plumbing supplier) locally would have been prudent.
My test consisted of pushing a laundry sink into the 1.5" drain and fiddling to ensure a tight seal.
I used about 3 " of water and noted the height on two walls.
I waited 24 hours.
I noted no difference in height after 24 hours.
I did not notice any evaporation loss or leakage.
After draining the pan i then went under the crawlspace to inspect the plywood base and joists and noted no moisure or wetness.
I note your comments on measuring for leakage and evaporation.
Can you elaborate?
I have enclosed a pic of of the status of my job so far. But am not adverse to going back and re-testing.
Paul
oh'mike 06-01-2011 06:27 PM
Looking very fine--keep the pictures coming.
Bud Cline 06-01-2011 07:29 PM
Why is that little piece of duct tape on the pan liner?:eek: The one near the bottom.
Paul8434 06-01-2011 09:09 PM
Hi Bud,
Good eye. That was used as one of my markers to note the water level during the flood test.
Paul
JohnFRWhipple 06-02-2011 09:01 AM
Measuring for evaporation
On an extended flood test with hot job site conditions or excessive air movement you need to measure the rate of evaporation.
We set up a second dish of water. Something like a casserole pan and fill with a inch or so of water. We add a stack of coins to both the casserole pan and shower pan. Both will evaporate at the same rate.
By using coins you can see exactly if the pan is leaking and by what rate.
I just noticed your in Vancouver. Call me when you do your next shower and I will lend you a plug.
JW
Bud Cline 06-02-2011 03:07 PM
Jheeeeezh!
You guys in Canada don't have a ruler or a yardstick or a tape-measure device?:)
JohnFRWhipple 06-02-2011 03:19 PM
Originally Posted by Bud Cline (Post 659869)
Jheeeeezh!
:laughing:
