Shower Pan/drain Install - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-11-2013, 04:53 PM   #1
Shower pan/drain install
After removing old shower pan and liner I was left with 1 1/2" PVC coming out of 2" PVC. The 1 1/2" is quite flimsy. The 1 1/2" only goes into 2" only to about 6" down. Look at attached picture. Not sure exactly what to do at this point. Can I just pull this 1 1/2" out and use the 2"? It seems as though a slight tug would pull it out. Why would it be plumbed this way to begin with? Totally lost here...any suggestions would help. The shower pan and liner were done completely wrong and I'm pretty sure that this is another example of this. Thanks.
Shower pan/drain install-image-1088881608.jpg   Shower pan/drain install-image-4017678577.jpg
raiderred222 is offline   Reply With Quote
Old 06-11-2013, 05:08 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by raiderred222 View Post
After removing old shower pan and liner I was left with 1 1/2" PVC coming out of 2" PVC. Can I just pull this 1 1/2" out and use the 2"?
If you're really lucky. Otherwise? Think about what else would be easier to do with the rotary hammer you'll be renting for a 1/2 day.
SWAG: The shower pan showed up with a 1.5" drain. Git 'er done!
Old 06-11-2013, 05:40 PM   #3
use the 2 inch and be glad it was there. you got lucky which doesn't happen often in remodeling.
Old 06-11-2013, 06:04 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 444
could the 2" just be a sleeve around the smaller pipe? Have you actually pulled the 1.5" pipe out?
Showers are supposed to be 2" but you see them 1.5" now and then
Old 06-11-2013, 06:12 PM   #5
Thanks for the help. I pulled the 5" piece of 1.5" out and plumbed new drain to the 2". It looked to me like the previous contractor or owner siliconed in a piece of 1.5" into 2" because they were too lazy to chip a little bit of cement to plumb with 2". Which would explain why the shower pan was so thick!
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 10:30 AM
Frameless Glass Shower Install lynxpilot Kitchen & Bath Remodeling 12 10-24-2012 12:14 AM
How to install Granite Shower Shelves dave-diy Kitchen & Bath Remodeling 12 11-25-2011 05:08 PM
Shower has drywall (not green) can I install Cement board Right over it? jwhiteuwc Drywall & Plaster 14 02-03-2009 03:20 PM
How to install a preformed shower base Ironman Plumbing 2 01-15-2009 09:36 PM
