-   -   Shower pan/drain install (http://www.diychatroom.com/f15/shower-pan-drain-install-181676/)
raiderred222 06-11-2013 03:53 PM
2 Attachment(s)
After removing old shower pan and liner I was left with 1 1/2" PVC coming out of 2" PVC. The 1 1/2" is quite flimsy. The 1 1/2" only goes into 2" only to about 6" down. Look at attached picture. Not sure exactly what to do at this point. Can I just pull this 1 1/2" out and use the 2"? It seems as though a slight tug would pull it out. Why would it be plumbed this way to begin with? Totally lost here...any suggestions would help. The shower pan and liner were done completely wrong and I'm pretty sure that this is another example of this. Thanks.
TarheelTerp 06-11-2013 04:08 PM
Originally Posted by raiderred222 (Post 1199351)
After removing old shower pan and liner I was left with 1 1/2" PVC coming out of 2" PVC. Can I just pull this 1 1/2" out and use the 2"?
If you're really lucky. Otherwise? Think about what else would be easier to do with the rotary hammer you'll be renting for a 1/2 day.
SWAG: The shower pan showed up with a 1.5" drain. Git 'er done!
DannyT 06-11-2013 04:40 PM
use the 2 inch and be glad it was there. you got lucky which doesn't happen often in remodeling.
TheEplumber 06-11-2013 05:04 PM
199 Attachment(s)
could the 2" just be a sleeve around the smaller pipe? Have you actually pulled the 1.5" pipe out?
Showers are supposed to be 2" but you see them 1.5" now and then
raiderred222 06-11-2013 05:12 PM
Thanks for the help. I pulled the 5" piece of 1.5" out and plumbed new drain to the 2". It looked to me like the previous contractor or owner siliconed in a piece of 1.5" into 2" because they were too lazy to chip a little bit of cement to plumb with 2". Which would explain why the shower pan was so thick!
