Shower Pan 1/2 Destroyed - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-18-2011, 05:40 PM   #1
shower pan 1/2 destroyed
We arenít sure where to start. It appears that there was a tile shower there originally which the base has been partly destroyed. Whatís left appears to be angled correctly but the drain is not in the middle. There is no moisture barrier of any type. It looks like they poured concrete on top of the slab base and then applied the tiles to this. Iím not sure where to start. Do we need to take up the previous pan or can we add / fix whatís there? Should everything be taken up down to the slab? What do we do about the moisture barrier? I need step by step instructions. Thanks
shower pan 1/2 destroyed-img_1866.jpg   shower pan 1/2 destroyed-img_1862.jpg
JRedd is offline   Reply With Quote
Old 03-18-2011, 06:43 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That's a mess that apparently no one understands so take it all out and start over. We can supply you with a few of the proper procedures at that point. There is more than one way to do this. The drain doesn't necessarily have to be in the center but it would be better if it was.
XXX
Old 03-18-2011, 11:01 PM   #3
I figured we'd have to take it all out but was hoping for the best. What should I do with the drain?
Old 03-18-2011, 11:42 PM   #4
Rewards Points: 6,652
Everything out down to bare wood, and if you have to, may have to cut out the sub floor and replace with Marine grade ply, or exterior grade before doing it the correct way.
Old 03-19-2011, 09:23 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
gregzoll:
"Everything out down to bare wood, and if you have to, may have to cut out the sub floor and replace with Marine grade ply, or exterior grade before doing it the correct way."
U-m-m-m-m-m-m-h! I think it's on a slab.
XXX
Old 03-19-2011, 10:46 AM   #6
Really could not tell from the picture.
Old 03-19-2011, 11:38 AM   #7
It is on a slab
Old 03-19-2011, 12:11 PM   #8
Originally Posted by JRedd View Post
It is on a slab
I think that it has already been cleared as that it is a slab.
Old 03-19-2011, 05:24 PM   #9
Here are a few pictures that I hope clear up any confusion.
shower pan 1/2 destroyed-img_1871.jpg   shower pan 1/2 destroyed-img_1869.jpg
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 09:03 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
