Shower Lighting Question. - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-19-2011, 09:01 AM   #1
Shower lighting question.
I am having an ICAT recessed 6" can put into my bath/shower area. It will have a shower trim over that. What is the largest Par30 watt bulb a person can put in that type of enclosure? Thanks.
ingeborgdot is offline   Reply With Quote
Old 05-19-2011, 11:36 AM   #2
Rewards Points: 150
It should tell you the max wattage inside the fixture.
josall is offline   Reply With Quote
Old 05-19-2011, 06:33 PM   #3
Rewards Points: 5,336
Usually it's 60 watts and it would be a regular bulb, not a flood light.
As said, it should be stated on the can. just look for the trim your using as that's what will dictate the bulb size and type.
Ron
Old 05-19-2011, 06:57 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Keep in mind most of those can lights these days have a thermo-disconnect and will shut off if a too large bulb is used.
XXX
Sealer Question for shower chope Plumbing 0 11-11-2010 09:17 PM
Shower hot water question cellophane Plumbing 2 03-08-2010 08:30 AM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
Hardiebacker 500 in shower enclosure question (does board facing matter?) DyerWolf General DIY Discussions 3 01-20-2009 06:58 PM
Question about shower valve? Rick Bruner Plumbing 3 03-23-2008 10:09 PM
