Shower Installation - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-26-2012, 11:38 AM   #1
Williamparrish's Avatar
shower installation
I need to add a shower enclosure to the existing garden tub in a mobile home.
Williamparrish is offline   Reply With Quote
Old 11-26-2012, 01:03 PM   #2
Rewards Points: 236
and your question is ?
Fix'n it is offline   Reply With Quote
Old 11-26-2012, 02:12 PM   #3
I need to the find out the steps. This is my first project.
Not sure of how to finish the enclosure. I can frame the walls.
Old 11-26-2012, 02:45 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
THAT is not a good idea with that arrangement. I would discourage any attempt to do so.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
joecaption (11-26-2012)
Old 11-26-2012, 03:36 PM   #5
Rewards Points: 2,516
From what I see you have 2 steps covered with carpet. You can't find them. they are right in the picture.
hammerlane is offline   Reply With Quote
Old 11-26-2012, 04:18 PM   #6
Rewards Points: 258
http://www.saferwholesale.com/Brand-...FSWoPAodCmAAYQ
install one of these
redman88 is offline   Reply With Quote
Old 11-26-2012, 05:30 PM   #7
Not the steps you stand on, the steps you take to build the enclosure.
Old 11-26-2012, 06:00 PM   #8
Rewards Points: 14,026
The whole plan with what you have to work with is wrong.
A drop in tub is far more likly to leak under the lip around the top.
Carpet never, ever should have been installed there in the first place. A sire way to have mold and rot under it.
About the only way I see it being done is with one of these.
Going to look like poop but should keep most of the water inside the tub.
http://www.amazon.com/s?ie=UTF8&keyw...20shower%20kit
Old 11-26-2012, 06:10 PM   #9
The carpet is being ripped up and tiled
Old 11-26-2012, 06:22 PM   #10
Going to have to remove the tub to be able to do tile.
By the time you add tile board and tile it's going to be to high around the tub if it's left in place.
If you really want a shower you would be far better off getting rid of that whole tub and installing a real tub and shower.
When you remove that carpet if that was original to the home, I'd bet your going to have rebuild that whole thing to make strong enough to support tile and not have it crack.
If they just used patical board it's all got to go.
Old 11-27-2012, 10:42 AM   #11
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Other things not withstanding, How are you planning on keeping the water IN the tub? The only way to do this is with a round curtain system like you see over the old clawfoot tubs.
I have one of these in our guest bath. It is such a pain in the back end I let house guests use the shower in our master bath.
The curtain is clammy, it grabs you, Not to mention there is absolutely no where to put your shampoo or soap.
I would seriously rethink this.
Even if you manage to do this, you won't be happy with the results.
Bite the bullet, and put a real shower in.
Old 11-27-2012, 11:08 AM   #12
Plumber
TheEplumber's Avatar
Rewards Points: 830
I'd gut the room, replace the garden tub with a standard multipiece fiberglass tub shower unit. Finish the floor with vinyl. A manufactured home floor system is not designed for tile
Sent from my iPhone using DIY Forum
Old 11-27-2012, 12:05 PM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
To say nothing of the free-standing water supply pipes and shower head. Just not a good idea at all. Trailer homes are not constructed substantially enough to support most tile installations. The wind blows and the grout cracks.
XXX
Old 11-27-2012, 11:16 PM   #14
bad idea all the way
Old 11-28-2012, 09:10 AM   #15
Rewards Points: 258
older mobile/manufactured homes are crap built, newer ones, are held to a higher standered then Stick built homes. though with carpet around the tub i would say its an older mobile home
Shower Installation on Concrete Flooring marco427 Building & Construction 5 08-05-2012 01:49 PM
shower door installation cfio General DIY Discussions 3 10-20-2010 07:52 AM
Shower gasket flange installation lcgall Plumbing 2 09-23-2008 08:08 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 07:43 PM
Shower installation help needed neonrider General DIY Discussions 1 08-24-2005 05:15 PM
