Shower Curb Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-04-2013, 12:29 AM   #1
Shower curb question
I have a concrete floor with the framing and plumbing complete. I want to build the curb so that I can tile the rest of the bathroom and put the toilet and vanity in place and come back to do the shower later. My question is how do I secure the the boards to the concrete floor or should I use a different material. Thanks.
jayzlookz is offline   Reply With Quote
Old 08-04-2013, 05:11 AM   #2
DIY staff
Rewards Points: 7,174
How to build a shower - Building a shower pan with pre-sloped mortar bed, liner and curb.
Screw the bottom plate to the floor using Tapcon screws----Mike--
Old 08-04-2013, 10:17 AM   #3
Rewards Points: 240
a few years ago, when i was doing the shower in my condo, concrete floor. the guys on the forums said DO NOT use any kind of wood for the curb. i used paver blocks and mortar.
Fix'n it is offline   Reply With Quote
Old 08-06-2013, 03:39 PM   #4
CitadelBlue's Avatar
Rewards Points: 97
that makes sense .....
CitadelBlue is offline   Reply With Quote
Old 08-06-2013, 05:39 PM   #5
Yes as Fix'n it says, using wood is a bad idea. I'm not sure if these are available in the US, but in Australia Hebel blocks are the most common curb (hob) now. Here is a video of the installation.
<iframe width="420" height="315" src="//www.youtube.com/embed/wZISui8Cw5Q" frameborder="0" allowfullscreen></iframe>
Ah embedded videos not allowed it seems.
see it here http://youtu.be/wZISui8Cw5Q
My question though would be why are you building a curb at all? If you are building on a slab, then it's a much nicer look to have a walk in shower with no curb. But this requires a second drain in the bathroom, in case there is a blockage in the shower drain. I also wonder what you did for a drop (slope) in the concrete slab to the drain?
roger_ is offline   Reply With Quote
Old 08-06-2013, 08:40 PM   #6
Rewards Points: 240
Originally Posted by roger_ View Post
Y
my slab was not poured to do no curb. but i did a low curb, it was under 4" on the outside and about 2" on the inside.
The Following User Says Thank You to Fix'n it For This Useful Post:
oh'mike (08-06-2013)
Old 08-07-2013, 05:23 PM   #7
Or you could have ground the slab with a concrete grinder. They look so much nicer without a curb.
Old 08-19-2013, 01:11 PM   #8
You could use a a hand-held power hammer that uses .22 load and different types of fasteners that you can insert into the barrel of this device. All you do is strike the firing pin side of the device and the .22 shell will drive the selected fastener into the concrete.
lenville is offline   Reply With Quote
Old 08-19-2013, 09:53 PM   #9
Rewards Points: 960
It isn't too big of a deal to cut out that concrete and build it without a curb.
If this is a no go, I would opt for building the curb with brick or block or whatever and not wood, and going with a laticrete drain and hydroban the whole thing. This will save you a step.
You might want to post some photos or a diagram. When you say that it is all ready to go, I'm not sure what that means. Is the pre-slope done and the drain is set?
cleveman is offline   Reply With Quote
Old 08-20-2013, 08:21 AM   #10
There arte a lot of choices here. If you use wood your pan liner material needs to be hot mop ( I prefer this and done right these shower curbs last 50 years ). Use a Ram set to secure it to the slab, a bead poly urethane on the slab first is cheap insurance, treated lumber only 3ea 2x4's stacked, nail it to the bottom plate of the walls also. Hot mop, then float it in mud 1" thick all around. This is the preferred method or the CTIA.
I have always hot moped but the newer systems seem to be gaining in popularity.
vinceg14 is offline   Reply With Quote
Old 08-20-2013, 08:41 AM   #11
Nowadays you can buy premade shower kits with premade curbs that can be cutt. To fit any size you want.. Yes there are different ways but for a novice i would go with a presloped kit.. This is agreat system check them out..
http://www.noblecompany.com/
Peppe1019 is offline   Reply With Quote
Multiple Shower Head/Water Pressure Question MikeDobbs Plumbing 13 02-27-2012 11:40 PM
beginner's question about shower fixtures diy'er on LI Plumbing 6 02-19-2012 10:05 PM
Prep Shower Walls / Shower Bench Question LeviDIY Remodeling 8 06-10-2011 05:09 AM
Custom Shower Plumbing Question PhilStubbs Plumbing 0 04-24-2011 09:39 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
