Shower Corner Shelf Installation - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-22-2009, 04:23 PM   #1
shower corner shelf installation
Looking at a Majestic ceramic corner shelf, it appears it mounts flush to the wall tile, different from how the soap dish is constructed and mounted. Is this correct and how is this attached?
brenner is offline   Reply With Quote
Old 02-26-2009, 04:01 PM   #2
Rewards Points: 5,336
There should be instructions in the box. Can you post a link?
I get no hits on Google about this product.
Ron
Old 02-26-2009, 05:33 PM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
What type of material is it made off.if its a stone product it gets mounted while the tile is being installed with thin-set. then the tile gets cut around it .I'm not sure on the type of shelf you have. BOB
Old 02-26-2009, 07:45 PM   #4
Ron 6519, thanks for the response. No instructions came in/with the box.
buletbob, thanks for your response. What you indicated is what it appears but sure looks like it would be/should be mounted directly to the tile.
brenner
Old 02-26-2009, 08:16 PM   #5
buletbob's Avatar
could you post a pic of the item. BOB
Old 02-26-2009, 10:03 PM   #6
A corner shelf made of stone like material? I don't understand how it could possibly be attached to the surface of the surrounding tiles with any integrity. Even if something like silicon caulk were strong enough to keep the corner shelf attached to the tile how could it support the weight of not only the shelf but also anything else you might put on it?!? Silicon caulk is amazing stuff, but not that amazing.
I think Bob may be correct; that it's attached during the tiling process with Thin-Set cement so it becomes part of the walls themselves, in order to get the strength and integrity it needs to support its own weight and the weight of anything else you put on it.
I'm an amature, and don't know much, so maybe someone can set me straight, but I just don't understand how much of anything could be attached to the surface of any ceramic or porcelain tile waterproof surface with the strength needed to support any weight for very long?!? Good luck. Rich
Rich Metzger is offline   Reply With Quote
Shower Stall shelf helpless handyman Building & Construction 3 08-28-2008 10:45 PM
Who makes a good corner shower??? murray59 Plumbing 3 06-03-2008 02:26 PM
New Shower Valve Installation wagnersr Plumbing 1 04-03-2008 08:11 AM
Shower installation help needed neonrider General DIY Discussions 1 08-24-2005 05:15 PM
