Should I Remove Old Blown Insulation In Exterior Walls - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-29-2012, 10:18 AM   #1
Should I remove old blown insulation in exterior walls
I have removed old sheetrock and found lath board still on walls, with blown insulation in wall, Should I remove old insulation, and re-install new Batts? Will I gain anything? And should I put a moisture barrier on the wall before I re-install sheet rock Thanks
jimlane is offline   Reply With Quote
Old 01-29-2012, 11:07 AM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by jimlane View Post
I have removed old sheetrock and found lath board still on walls...
Will you be removing the lath as well?
If so, you'll have little choice but to replace the insulation there.
How to handle a vapor barrier depends on what else is happening there.
Old homes can be complicated.
Old 01-29-2012, 06:57 PM   #3
Registered User
Rewards Points: 4,888
Welcome to the forums!
1. Where are you located?
2. Describe the wall make-up.
Gary
Old 01-29-2012, 07:15 PM   #4
Rewards Points: 12,790
I would. The reason being in an old house like that there's a very real chance or outdated wiring, no blocking at the top and bottom of the walls,
Unsealed areas were wiring was run, settled insulation under windows, at the top of walls and under the diaganals in the outside corners.
Since it's all down I'd also be seailing around the old window frames under the casing with expanding foam.
blown in insulation in the rain? bubbler Insulation 12 10-19-2011 10:10 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 01:42 PM
Removing old attic blown in insulation and 52Caddy Remodeling 12 03-28-2010 12:19 AM
Remove old insulation in attic? powerman4160 Building & Construction 10 01-30-2009 05:12 PM
removing blown insulation jestersma Remodeling 8 05-30-2006 03:47 PM
