Old 08-08-2014, 10:40 AM   #1
Share |
Should I re-use this baseboard, or buy new?
I removed all of the baseboard trim for drywall and flooring work. It all came off pretty easy, with very little damage. I was going to replace it, but I was thinking it might save me time and/or money if I filled the holes, repainted it, then re-installed it, since it's already cut to size. If I do buy new I can borrow a miter saw, so that's not a cost to be factored.
What would you do?
Joe Link is offline   Reply With Quote
Old 08-08-2014, 10:59 AM   #2
Knows Enough to be Danger
What is the advantage to replace it? Do you want a different style?
I'm always of fan of not replacing what I don't have to, but that's just me.
NickTheGreat is online now   Reply With Quote
Old 08-08-2014, 11:22 AM   #3
Nope, I like that style.
That's what I was thinking, but I didn't know if saving it would be more work than it's worth. I haven't priced new stuff, so I have no idea what it'd cost.
Old 08-08-2014, 12:50 PM   #4
I don't think we can answer that, depends on how good you want it to look
scottktmrider is offline   Reply With Quote
Old 08-08-2014, 01:13 PM   #5
I want it to look perfect :P
Old 08-08-2014, 08:20 PM   #6
(the original)
That's determined by the effort you put into it, not whether you use old or new materials.....
ratherbefishin' is offline   Reply With Quote
The Following User Says Thank You to ratherbefishin' For This Useful Post:
Joe Link (08-08-2014)
Old 08-09-2014, 09:05 AM   #7
Very true!
Old 08-09-2014, 09:45 AM   #8
Gymschu's Avatar
I guess I'm in the minority here in that I like to save/salvage what was there in the first place. Joe, that looks like the cheap pressed wood or plastic trim, but I can't really tell from the pics. I would clean it up (remove old caulk, wood filler from nail holes, etc.) and reinstall it. Then recaulk and refill, sand, and repaint. DONE.
Gymschu is online now   Reply With Quote
Old 08-09-2014, 09:47 AM   #9
STAFF
BigJim's Avatar
If it were mine I would use what I already have, why replace something with the same thing, check the cost on the new stuff, you might want to use what you have. JMHO
New members: Please consider adding your location to your profile.
Jim
BigJim is online now   Reply With Quote
Old 08-09-2014, 10:52 AM   #10
Thanks guys. I'm going to sort it out, re-check the condition, and try to re-use it.
Old 08-11-2014, 11:11 AM   #11
Was it nailed on or glued on? when reusing trim, I cut the nails off with a dremel and cut off disc as pounding them back thru does a lot more damage. Cut them of and renail.
B
Beepster is online now   Reply With Quote
Old 08-11-2014, 11:34 AM   #12
STAFF
BigJim's Avatar
If I had to get nails out of trim, I pulled them out through the back, driving the out the front will damage the trim, like Beepster said.
Jim
Old 08-11-2014, 01:07 PM   #13
They were nailed on. I flipped the trim over, layed it flat on the floor, then used the side of a pair of pliers and leverage against the wood to twist them out. Worked great!
The Following User Says Thank You to Joe Link For This Useful Post:
BigJim (08-11-2014)
Old 08-11-2014, 02:15 PM   #14
47_47's Avatar
Hope you marked where they belong
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is online now   Reply With Quote
Old 08-11-2014, 02:20 PM   #15
That's half the fun, isn't it?? :D
I hadn't planned on re-using them, but it won't be difficult. The condo is only 714 sq ft.
Baseboard. A Big Deal Question! altc81 Flooring 15 11-03-2013 03:00 PM
Rotted Baseboard miamicuse Carpentry 11 09-08-2013 09:09 AM
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 09:30 AM
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 09:48 PM
Baseboard dilema Allyson Flooring 5 09-04-2009 08:30 AM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
