Should I Insulate Basement Room? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-30-2012, 09:26 AM   #1
I want to build one room in part of my basement. Two of the framed walls would be against two of the conrete basement walls, with the remaining framing not against any concrete. I plan to heat the room, when necessary (not often), with a small portable space heater. Most of the basement finishing info I have seen shows insulation in the framed walls. In my case, is there any reason/benefit to insulating? TIA!
Micker is offline   Reply With Quote
Old 07-30-2012, 09:33 AM   #2
Rewards Points: 12,790
If you going to heat it then insulate all of it.
Old 07-30-2012, 10:15 AM   #3
bbo
Insulation also adds sound deadning in addition to making the space easier to heat and keep heated when needed.
what does the portable space heater use for fuel? I would not use anything intended to have venting in an enclosed area.
bbo is offline   Reply With Quote
Old 07-31-2012, 07:36 PM   #4
Thanks. No, it's an electric heater.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Foam Insulate All Basement Walls? VikingDinKC Remodeling 44 01-30-2012 10:43 PM
finishing a room in the basement infamshxr Building & Construction 17 12-14-2011 10:38 PM
Would it benefit me to insulate my basement floor? Hawss Drew General DIY Discussions 12 01-14-2010 09:08 PM
soundproofing a basement rec room jtim1152 Remodeling 3 09-10-2009 05:01 PM
