Should I Go W/ Glass Blocks?? - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-30-2012, 05:01 PM   #1
Professional Novice
Sadde10's Avatar
Should I go w/ glass blocks??
I am thinking of putting translucent glass blocks in this void under the soffit and right of the walk through door. This will separate the long rec room and future office w/ attached half bath that is in my basement project.
I am looking for knowledge on installing the blocks, which ones to purchase/size and whether or not it is a good idea. Here is a pic of the area I am thinking. Thanks!
Should I go w/ glass blocks??-100_1477.jpg
Sadde10 is offline   Reply With Quote
Old 11-30-2012, 06:31 PM   #2
So the rec room is on one side and the office is on the other? I'm not sure I've seen two spaces like that separated by a glass wall. Are there features in the two spaces that you want visible to the other?
I don't have anything to offer about installing the block, just trying to understand what you're going for with the space. If nothing else, this will bump your thread
emagsamurai is offline   Reply With Quote
Old 11-30-2012, 07:14 PM   #3
funfool's Avatar
Rewards Points: 534
I love glass block in the correct location. I like them in a dark stair well, they look good next to a door, basically anyplace you want to let light in but not deal with shades and curtains.
One house the master bedroom was divided by glass block above the jacuzzi tub of master bath ... whoo hoo! kinda sexy watch shadows of wife taking a bath.
We kinda have it down to a science, at $65 per hour for labor, price of glass block and installation is close to $25 per block.
This includes finish on both interior and exterior sides, is just labor to install a 8"x8" block and build a window.
I am just saying, for a customer they often think that a block is $4 and has to be cheaper then a new window.
A new window would cost $500 and take 15 min to install and more time to finish drywall.
Same size opening in glass block will cost them $800, just more labor to install.
Since you are doing labor, would be cheaper.
Is glass block mortar, and glass block spacers, you need to do the math and build opening to the correct dimensions, but not hard to install.
You can not cut 1/2 a glass block, so framing needs to be correct, other then that have fun.
funfool is offline   Reply With Quote
Old 11-30-2012, 07:18 PM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
In my opinion, glass block is one of those design elements that needs to have most everything else designed around it. Not to just throw it in somewhere that was not designed specifically for it.
If that makes sense.
I think you would be better off with a grid of obscured glass panels in that area. Not my first choice but something to think about.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 11-30-2012, 08:19 PM   #5
Professional Novice
Sadde10's Avatar
Interesting...keep em' coming.
Old 11-30-2012, 08:22 PM   #6
Professional Novice
Sadde10's Avatar
No features, just something that I haven's seen done before. Kinda thought , if anything, that it would help with the light considering I have windows on the westside and not on the east.
Old 12-01-2012, 05:19 AM   #7
kwikfishron's Avatar
Rewards Points: 798
You may want to a consider acrylic block window. They look just like the glass and have lots of different options, they can even be lighted. Iíve used this company for both interior and exterior applications with no issues. http://www.hy-lite.com/Hy-lite-US-Bl...ws-Welcome.cfm
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Sadde10 (12-01-2012)
Old 12-01-2012, 05:46 AM   #8
DIY staff
Rewards Points: 7,174
I'm a lousy mason---I have the blocks made into panels at the brick yard----they mortar them and place a steel band around the panel---makes installation quick and easy for a poor mason---
Old 12-01-2012, 10:32 AM   #9
Professional Novice
Sadde10's Avatar
Andy.
Thanks Andy, if you don't mind me asking what would be your first choice?
Old 12-01-2012, 10:39 AM   #10
Professional Novice
Sadde10's Avatar
I am no Mason either, heck I barely have any carpentry knowledge! Which after reading what funfool said, I don't think this is one of my better ideas.
I like the Acrylic idea though.
And getting something framed and brought down into my basement would be pretty difficult. Heaving drywall down there is fun enough.
Old 12-01-2012, 10:46 AM   #11
DIY staff
Having a helper is a real dream----I'm thirty miles from the job and the drywall is being taped as I sit at this computer----
The glass block panels are makes is manageable sections--then the sections are put together with mortar---
Old 12-01-2012, 02:47 PM   #12
funfool's Avatar
Rewards Points: 534
oh,mike I agree with you.
Just seems I never have all my ducks lined up, everytime I try to order something like that is 2 or 3 weeks out, no thanks just build it myself.
But is good option to order them like this.
Old 12-01-2012, 06:02 PM   #13
DIY staff
I have a busy brick yard not far away ---they have them made in a day or two---and will deliver for a small fee----
Tags
basement , glass block , office
Triangular glass blocks and using them on an angle KissMeKate Tiling, ceramics, marble 3 06-03-2012 05:11 PM
Shower remodel with glass blocks. Towerdog2 Kitchen & Bath Remodeling 10 07-13-2011 09:14 PM
Glass Blocks in place of railings fixerupper84 Building & Construction 3 02-26-2011 12:09 PM
Glass Blocks on top of Bathtub? weight? EuroZ24 Building & Construction 4 11-08-2009 09:40 AM
Replace window in shower with glass blocks organick Kitchen & Bath Remodeling 6 10-10-2009 09:45 PM
