Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-15-2007, 03:06 PM   #1
should I chisel door hinges deeper to accomodate primer/paint?
Just finished chiselling the 3 hinges for my new front door, and they came out extremely perfect if I do say so myself
The problem I just foresaw is that, once I remove the hinges/door hardware, prime it, 2 coats of paint, all of a sudden my hinges won't fit anymore... Am I overanalyzing this? <just paranoid I'm gonna mess it up, the slab was over $100 and I just really don't want to ruin it!>
joeyboy is offline   Reply With Quote
Old 09-15-2007, 03:13 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Just don't paint the hinge mortise recesses themselves. It's not going to matter that you don't paint them. The hinge plates will cover....
- Build Well -
Old 09-15-2007, 05:52 PM   #3
I thought I had to make sure I covered all of the wood with paint/primer to ensure minimal moisture intake/swelling/receding? If the hinges will do the job just as well then that's just awesome, because I can't even explain how long it took me to chisel those 3 hinge recesses (I was determined to do them perfectly, and it took a loooong time lol, as it was my 2nd time chiselling wood ever).
Old 09-15-2007, 06:26 PM   #4
Home Improvement Guy
ron schenker's Avatar
Just how thick could primer and 2 topcoats be?
ron schenker is offline   Reply With Quote
Old 09-15-2007, 07:44 PM   #5
not thick at all - but as I said, I was hyper-anal ( ) doing my chiselling work, so they're 100% flush. You almost need to squeeze the hinges into place, so if there were paint they prolly wouldn't go in and I'd need to sand off the paint. Basically if I was going to need to paint those, I'd chisel off a slight bit more to accomodate.
Old 09-15-2007, 07:48 PM   #6
Mod / ArchiBuilder
Cole's Avatar
Im glad to see I am not the only anal one here about little details.
Cole is offline   Reply With Quote
Old 09-15-2007, 08:58 PM   #7
I was *never* that way. After spending an obscene amount of hours on this site's sister contractor site, I got into a strong mindset of doing everything 100%. If I ever feel I'm taking a shortcut, I feel it's automatically wrong lol! But yeah, I try to treat every project I do as if it was going to be scrutinized by professionals. I'm doing sooo many projects on my house, I guess that if I didn't do it with that mindset, when I was done, I'd be paranoid that there were little details that were wrong everywhere
Old 09-15-2007, 09:26 PM   #8
I can see the point of "Sealing" every surface area of a door to avoid some swelling. We advise Home owners about that all the time, when they want to ..... "do the paint work themselves".
You could: Spray some primer sealer over the hinge mortise areas prior to painting the rest of the door. Spraying a coat will not be as thick as applying primer and top-coat paint with a brush....
BTW- Coats of paint will definitely affect the way a door operates if the areas of conern are "tight" to begin with, prior to applying primer and paint....
- Build Well -
Old 09-15-2007, 09:27 PM   #9
...It's the "details" that make the difference.....
- Build Well -
Old 09-15-2007, 10:05 PM   #10
100%!!!!
Old 09-16-2007, 01:01 PM   #11
You should be able to clean up the paint with a light shearing of the surface.
Ron
