Should I Caulk The Entire Window? - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-28-2012, 11:37 PM   #1
Should I caulk the entire window?
Recently I had some rotting trim replaced on the exterior of a bathroom window. It's an east facing window (in N. California) and does show signs of humidity on the inside in the mornings. But... only the lower exterior corners showed signs of rot. The exterior vent holes were clean and open. The question is 'what caused the rot' and 'now that it's been repaired should I caulk the circumference of the new trim?'
The exterior of the house is Wyerhauser style siding. But that's an entirely different story.
Any help would be appreciated.
Ray
rayworx is offline   Reply With Quote
Old 06-28-2012, 11:45 PM   #2
Renovations contractor
Bonzai's Avatar
Lots of styles of windows and different ways of doing trim. Not that a photo is likely to show the problem as you've already fixed it, but anything else will be pure speculation and guess work.
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 06-28-2012, 11:52 PM   #3
Rewards Points: 558
take a look here: http://ca.video.search.yahoo.com/vid...mhpvph&newfp=1
epson is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Stinky Caulk around window. Only when cold outside and receives direct sun. mvigadi Building & Construction 1 12-08-2010 12:01 PM
my fix for rotting outside sill on wooden window guest General DIY Discussions 6 11-06-2010 02:58 PM
window performance question renbelle Building & Construction 4 10-06-2010 02:25 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
