Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-30-2010, 10:02 AM   #1
Question
Should I block one of th two windows in my bedroom?
There are two windows, one's facing east and one's facing south. I want to block the south window to build floating bookshelves. Does it affect the value of the house if we block a window in the bedroom?
SaveNow is offline   Reply With Quote
Old 09-30-2010, 12:44 PM   #2
Stuck in the 70's
Blondesense's Avatar
Windows are good things. I don't know if it would hurt your value, but I don't see it helping.
A lot depends on what you mean by "block". If you mean patching the wall inside and out so there is no indication there was ever a window there, well, it is possible it may not hurt you too much. Unfortunately this is rarely the case. Even if the repair is perfect, a house will often look unbalanced from the outside.
On the other hand if it is obvious there is/was a window there, yeah. I don't see it being good.
Old 10-01-2010, 02:14 AM   #3
Thank you for pointing out the negative side of it. Does it look weird just to patch inside and leave outside as it is?
Old 10-01-2010, 09:36 AM   #4
Stuck in the 70's
I have heard of people painting the glass from inside and doing this. I think a lot depends on the location of the window. You would be more likely to get away with it if it is on the side of the home or hidden behind trees etc., rather than the front or back of the house.
Lastly, I have no idea about the construction side of this; how to insulate, if condensation/moisture buildup etc. would be an issue. Maybe someone with a construction background will post.
Old 10-01-2010, 09:51 AM   #5
Chicago, IL
Michael Thomas's Avatar
1) If you open windows for ventilation instead of using AC, you will lose the cross ventilation.
2 Will the remaining window meet the requirements for emergency egress, which include (in addition to other requirements):
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs
Michael Thomas is offline   Reply With Quote
Old 10-01-2010, 12:30 PM   #6
The house was built with bricks outside and drywalls on the inside. The window is on the back side of the home and blocking by a carport with wood fence.
There are two identical windows (52x35")
Here's a quick drawing of the house
What to do with windows when firring out from a block wall. willemdejong Carpentry 1 06-04-2010 12:25 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
Installing a new windows in cinder block foundation monsterbash Building & Construction 1 04-13-2009 08:48 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
