Short Partition Top Plate Wont Reach Second Beam - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-11-2012, 09:34 PM   #1
Rewards Points: 89
short partition top plate wont reach second beam
Building a short wall at the end of a tub. The wall is short enought thet it wont reach a second ceiling beam, or is it joist? anyway there will be two studs floor to ceiling 16 inch centers, there might be a third for making a pocket but will likey be inside that 16. and then stair step down to maybe 4.5 feet high.
So am thinking it is not secure enough with the top plate being attatched to just one beam, what are the ways to secure this, properly is better over easily. I dont want Mike Holmes comeing in and making a tv show out of my construction work. LOL
papason is offline   Reply With Quote
Old 06-11-2012, 09:50 PM   #2
Haverhill Trade 1965
If you can access the joists above you can put a 2x6 or 8 block on the flat, between the two joists, centered over the wall. That gives you nailing on the end and each side for drywall, strapping etc.
Duckweather is offline   Reply With Quote
Beam build, joint not over post WillK Building & Construction 8 01-03-2012 10:31 AM
drilling through steel I beam DIYguy2000 Building & Construction 3 11-21-2011 09:39 AM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 02:07 PM
Deck Beam connection to Post? CNJHomeowner Building & Construction 7 08-08-2008 07:14 AM
Building short section of wall to support new beam. Clutchcargo Building & Construction 5 04-13-2008 10:30 PM
