Sheetrock Over Tile Anyone? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-14-2008, 07:13 PM   #1
I got a mortar/tile bit and instead of smashing the pre-exiting 4x4 ugly brown tiles, I figured I could simply sheetrock over the tile and paint it. With a 1/2 " overhang, I could easily put molding there to mask the overhang.
Anyone ever done this? Any suggestions?
Callie
CallieT is offline   Reply With Quote
Old 02-14-2008, 07:51 PM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Never did it, never would. Remove the tile and then sheetrock.
I must ask though. Tile is usually used in moisture prone areas. Sheetrock would be bad in those areas. You sure you want sheetrock instead of tile in this area?
Brik is offline   Reply With Quote
Old 02-14-2008, 08:26 PM   #3
Blue Board over TILE anyone?
Hi Brik,
Yes, I have hardybacker, should have said that instead of sheetrock. The present tiles are very outdated, albeit in great conditon. I think a smooth wall would be more trendy, and I would be able to rent the apt easier. To smash the tiles and remove them would be yet another lengthy project as I am in the process of lifting up the linoleum floors in the kitchen to exposed hardwood with layers of tar paper and broken off nails to complete!
I can also use green or blue board instead of "sheet rock" cant I?
Just wondering how I can mask that 1/2" overhang at the mid wall?
Callie
Old 02-14-2008, 08:31 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I am sorry to say this, but, with a plan like that.... you sound like a "Hack-House-Flipper".
Honestly, that has got to be one of the worst ideas that a member has come up with and also insisted on a "blessing" for.
If you don't plan on having a mess....you need to remove it all, before proceeding with a proper substrate for installing tile...
- Build Well -
Old 02-14-2008, 08:42 PM   #5
Just Wanted A Quick Fix
Thank you for your honesty! I actually thought it was a great idea for a "quick fix".
As I am busy with the kitchen floor project, I figured it was too much to take on removing all the tile on the bathroom walls, and thought at first I could just cover the WET WALL on top of the tile. Then having said that...it looked so good, I was tempted to do the remaining 3 half walls the same way.
Looks like my plan backfired. Thanks again.
Callie
Old 02-14-2008, 09:14 PM   #6
Custom Cabinet Maker
Atlantic thanks that was my first thought; Can anyone say FLIPPER, complete remodel for 29.95 Than try to make 50K profit and only spend 2 days doing it
skymaster is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Tile over Sheetrock zmurphy Building & Construction 9 06-23-2007 03:45 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
