Sheetrock Over Sheetrock Add Insualtion? - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-30-2008, 09:49 AM   #16
Drywall contractor
Rewards Points: 1,070
If you use 25ga. metal, a 15ga. trim nailer will shoot through the studs. Once everything is caulked, it won't come down. (Use a little glue to be sure, if you like, as Atlantic said.) If you go to 20ga. the trim screws will likely be necessary. They can be a pain....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-30-2008, 09:52 AM   #17
Originally Posted by monkeywrench View Post
My existing walls in me bedroom are freezing, even with the heat pumping. the sheetrock was installed on 3/4" wood, nailed to the cyndeblock. There is no insulation either. I was thinking a quick fix would be just to put 5/8" rock right over the old sheetrock. Do you guys think this would help?
I didn't read all other posts but I would NOT put foam over the drywall.Foam is a vapour barrier and will trap mosture in that old drywall!the only real way to fix it is rip it down to block and use steel stud (2x4) then insulate with fiberglass pink or roxul and use super six barrier .Then re-drywall.remember that you can heat it easy if you insulate and isolate!!!
Orangeguy is offline   Reply With Quote
Old 11-30-2008, 10:13 AM   #18
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,186
Read the posts
Nobody said to put foam directly over the drywall. What I said was to strip it down, put up foam on the cinder block. That way it is a vapor barrier. Dorf Dude
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 11-30-2008, 10:19 AM   #19
Talking
like i said I didn't read all of the relpies.fair enough!
New medicine cabinet--old plaster and sheetrock help! garyofnyc Remodeling 4 10-31-2008 11:15 PM
Sheetrock mudding over existing painted textured surface? SKINNY Remodeling 8 10-13-2008 01:00 PM
Sheetrock nightmare MRZ Painting 12 05-25-2007 10:23 PM
pipe leak & sheetrock damage santogr General DIY Discussions 2 03-04-2007 02:44 PM
