Sheetrock On Ducts - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-20-2011, 01:23 PM   #1
sheetrock on ducts
Can I glue sheet rock directly to cold air returns in basement? I am trying to keep my headroom
Gtuff is offline   Reply With Quote
Old 12-20-2011, 01:55 PM   #2
retired union carpenter
Send a message via Yahoo to coupe
might work? but may get moisture?
as always, just my thoughts.
good luck
coupe/Larry
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 12-20-2011, 02:32 PM   #3
Rewards Points: 12,830
I would use a 2 X 4 frame around it or the rock may not stay stuck and fall down.
Old 12-20-2011, 02:37 PM   #4
DIY staff
Rewards Points: 7,174
Make the soffit work out of 1/2" ply or osb--with 2x2 corners--fast inexpensive and straight.
Duct work should never be used to support anything---they are not hung properly for that purpose.
Old 12-20-2011, 03:46 PM   #5
I framed ladders on each side of the return, flush with the u/s. Drywall spanned between. Worked great.
Marvel is offline   Reply With Quote
The Following User Says Thank You to Marvel For This Useful Post:
<*(((>< (12-20-2011)
Old 12-20-2011, 04:06 PM   #6
Love for Construction
<*(((><'s Avatar
You are concerned with losing headroom, correct? Why can't you just add framing along the sides of the return so that they are only an 1/8" lower than the return and screw the sheetrock to the framing, and span the return?
This way you would only lose 1/8" + the thickness of sheetrock 5/8" or 1/2".
-luke-
<*(((>< is offline   Reply With Quote
Old 01-30-2012, 04:31 PM   #7
This is my situation and I was thinking of spanning the drywall between two ladders on either side of the duct but the span would be 22" and although it would be supported on the ends via clips as well as the seams of the drywall on the wall I am concerned about sag in the middle (long term) and maybe some condensation or noise issues.
My current solution now is to use 1/2" MDF instead of drywall for strength, Install a 6 mil vapor barrier for condensation (just in case), as well as some acoustic sealant between the two to isolate any vibration.
Any feedback would be appreciated
Xygris is offline   Reply With Quote
Old 01-31-2012, 10:57 AM   #8
22 inches is nothing to worry about. After all most ceiling/roof trusses are placed at 24 inches o.c.
The Following 3 Users Say Thank You to Marvel For This Useful Post:
<*(((>< (01-31-2012), mae-ling (01-31-2012), Xygris (01-31-2012)
Old 01-31-2012, 05:39 PM   #9
Rewards Points: 2,202
You could use 1/2" ceiling drywall, it is stiffer then regular 1/2"
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
Xygris (01-31-2012)
Old 01-31-2012, 11:53 PM   #10
Oh yes, I had to look that one up because I thought it allowed you to install drywall in either direction but as it turns out it is also acceptable to have a 24" span. Sweet!!
http://www.usg.com/sheetrock-sag-res...ing-board.html
The Following User Says Thank You to Xygris For This Useful Post:
mae-ling (02-01-2012)
Can you glue to HVAC Ducts tro0925 HVAC 3 03-24-2011 04:31 PM
insulation types i can use between current and new sheetrock on ceiling philbee62 Remodeling 4 08-05-2010 08:12 PM
Sheetrock put on w/o removing door trim Carla33 Carpentry 13 12-26-2009 02:32 AM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 05:26 PM
Using PVC ducts instead of standard ducts robertmazzo HVAC 3 10-05-2006 05:26 PM
