Setting A Shower Base - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-25-2013, 10:37 AM   #1
Rewards Points: 49
Setting a shower base
i bought a fiberglass showerbase and was wondering if i should set it into portland cement of non shrink grout. Even if my floor appreas level, I should still set it into something right?
I bought two bags of non shrink grout for this purpose and was wondering if anybody had any objections to this non shrink grout.
thanks for input.
john_bry is offline   Reply With Quote
Old 02-25-2013, 10:45 AM   #2
Rewards Points: 13,260
What's it say on the manufactuers install instrutions?
Follow it to a tee!
Old 02-25-2013, 08:36 PM   #3
Rewards Points: 150
Never heard of non shrink grout never heard of shrinking grout . I do like to put them in concrete to stiffen up for weight tolerances
kaschmid3 is offline   Reply With Quote
Old 02-25-2013, 10:51 PM   #4
DIY staff
Rewards Points: 7,174
I usually use masons mix---regular brick mortar---your grout may work just fine---I've never used that--but I think it will work--
Old 02-25-2013, 10:54 PM   #5
I tryed grout one time, never again.
It set up to fast.
setting a shower drain Jackets Plumbing 16 05-10-2012 09:48 PM
Fix For ELM Shower Base Drain Leaks MarkSilber Plumbing 0 02-14-2012 10:02 AM
Plastic shower base and concrete / leveling issue JoTeeBee Kitchen & Bath Remodeling 2 06-17-2011 08:46 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
How to build base for a shower stall atm Plumbing 13 05-13-2009 11:18 AM
