Self Closing Hinge Removal - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-09-2008, 08:22 PM   #1
Self closing hinge removal
I need to remove the door between my garage and house to replace the weather strip and the door has two spring loaded self closing hinges. They are marked Stanley but no model #s. There is a roll pin driven into the center barrel and the lower portion of the hinge,I suppose to hold the spring, and there is a phillips head slot in the bottom where the pin of a normal hinge would protrude. The phillips slots will not move (someone has stripped the one on the center hinge). Do I need to unscrew these from the jam or door? How can I overcome the spring tension while I remove the screws to keep the hinge from snapping closed?
azhomeowner is offline   Reply With Quote
Old 11-10-2008, 08:26 AM   #2
Registered User
Termite's Avatar
The spring tension is probably fairly insignificant. If you can't get the pin out, then unscrew the hinges from the jamb.
Old 11-10-2008, 09:51 AM   #3
joed's Avatar
Rewards Points: 11,964
The pin is held in by the spring tension. Usually you sick something into one of the other holes twist and release tensionon spring. Remove the pin. Then move the pin to the next hole. Repeat until tension is removed.
Old 11-11-2008, 08:22 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
If I understand your description right, these are medium to heavy duty spring hinges and not the kind you'd find on a screen door. Use a punch in one of the holes around the top and release the tension on the spring. Then you can remove the pin and move it to another hole. You'll have to repeat the process several times until you have all of the tension released. DO NOT take the screws out until the tension has been released, unless you like having your fingers caught in a trap. When you rehang the door, you'll need to wind the tension back into the spring. If they are double acting (door swings both ways), you only need to release the tension on one side to remove the door. Be careful. These hinges love to pinch fingers.
Old 08-07-2012, 01:40 AM   #5
Rewards Points: 31
Question
same kinda question....
I am in need of doing the same thing to my self closing hinged door. So if I am reading this correctly, I can just release all the tension in the hinge and it will separate like a "typical" hinge and I can lift off the door? Or do I need to unscrew the hinges from the actual door frame and take it all off in one piece?
Thanks for your advice!
dgates12 is offline   Reply With Quote
Old 08-07-2012, 02:59 AM   #6
I read it as need to unscrew the hinge from the jamb and remove the whole thing with the door.
Evstarr is offline   Reply With Quote
The Following User Says Thank You to Evstarr For This Useful Post:
oh'mike (08-07-2012)
Hinge bits slipping winner155 Carpentry 6 10-19-2008 08:40 PM
Lead paint removal Luken8r Painting 3 05-15-2008 08:05 PM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 08:00 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
Re-Securing A Hinge In A Stripped Out Door Frame CGofMP Carpentry 9 05-05-2005 12:00 PM
