Securing Baseplate On Concrete W/ A French Drain Beneath It? Just Glue? - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-11-2012, 12:15 PM   #1
Rewards Points: 32
securing baseplate on Concrete w/ a french drain beneath it? just glue?
Our house was built by a local builder 19 years ago. The original owners had a drainage/water issue and had a company come in (Basement Dry) and put in a french drain?? around the interior perimiter and some "snake"spots through the floor. THey then patched it up with concrete.
The issue is, the concretet is patched concrete and not as thick as the rest. If I want to screw the base plate intot the original concrete I'll have to come out 6" from the walls.
Any way of securing this to the less thicker patch work that was done? Can you just glue the baseplate instead?
professorkev is offline   Reply With Quote
Old 01-12-2012, 12:02 AM   #2
Rewards Points: 2,202
Use the longest tapcon (concrete) screws you can and pl Premium or similar product to 'glue' it in place. It is amazing what this adhesive will hold. I am assuming the patched area is solid.
mae-ling is offline   Reply With Quote
Tags
basement , concrete , stud
interior french drain with integrated vapor barrier is a good idea? diy001 Building & Construction 16 12-08-2010 05:27 PM
French Drain or Trench Drain mikeylikesit580 General DIY Discussions 8 10-01-2010 12:17 AM
What's Needed for Drain Tile / French Drain samsmith Building & Construction 2 08-24-2010 12:20 PM
Existing French Drain Question chrisswany Landscaping & Lawn Care 4 08-17-2010 11:55 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
