Sealing Painted Basement Walls - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 06:45 PM   #1
sealing painted basement walls
I want to seal my cement-block basement walls with DryLok or similiar basement wall sealer.
However, the previous owner has applied at least 2 coats of regular paint over the years. This paint is now peeling/bubbling in places.
Should I just scrape away the peeling/bubbling paint and then apply the sealer or should I remove all the old paint(impossible?) ?
Thanks!
cmt9000 is offline   Reply With Quote
Old 07-05-2010, 10:13 PM   #2
cmt:
Here is the issue. If you only remove the parts where the paint has bubbled and then paint over it with a primer, sealer, etc., the new sealer will not coat evenly and you will be able to see the spots that you scraped. As painful as it might be, you need to scrape the entire wall in order for it to look good. Sorry, but it's true. I have been in the remodel business for more than 15 years, and have run into this issue several times.... usually when a basement has exposed to moisture. I was putting in a basement dehumidifier for a client, and when I went downstairs, all four walls had paint bubbling. The homeowner said, "I have been meaning to take care of that." My crew ended up scraping the walls and putting on a fresh sealer. I had three guys on the job and it took them about a week!
Take care.
Murry
Last edited by Scuba_Dave; 07-06-2010 at 10:12 AM. Reason: removed advertising links
murryc is offline   Reply With Quote
Old 07-06-2010, 05:50 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
Dry lock cannot be used over previously painted surfaces.
Q. Can DRYLOKŪ Masonry Waterproofer be used over paint?
A. Yes and no. DRYLOKŪ may be used over any other cementitious type waterproofing paint in good, repaintable condition, either inside or outside. However, DRYLOKŪ cannot be used over an oil or latex-based paint on the inside of a building. DRYLOKŪ will adhere to these paints, but if it cannot get into the pores of the masonry itself, it will not waterproof.
chrisn is online now   Reply With Quote
Old 07-06-2010, 12:26 PM   #4
Wow...that's a major job.
So should I just grab a wire brush and start brushing? I might be finished by 2020!
Why oh why did the previous owner do this? Argh....
Thanks guys!
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 08:45 AM
Finishing basement - concrete walls options droyer Building & Construction 1 01-13-2010 07:27 PM
painting basement concrete walls ctkeebler Building & Construction 6 11-17-2009 04:23 PM
basement walls citimauler General DIY Discussions 1 02-14-2008 08:18 AM
"floating" basement walls? greg s Carpentry 2 03-04-2005 08:56 PM
