Sealing New Sink Against Laminate Countertop - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-08-2011, 12:56 AM   #1
Rewards Points: 682
sealing new sink against laminate countertop
Right off the bat I think about running a bead of silicone and setting the sink in the bead.
Many old sinks/faucets I've removed were all packed under with plumbers putty. Maybe set the sink on a mess of putty, clean it off, and bead the outside with silicone?
What do you guys think is best? Thanks
darsunt is offline   Reply With Quote
Old 12-08-2011, 12:59 AM   #2
Rewards Points: 682
Also I think if I attach/tighten the garbage disposal to the sink, that's a lot of effort maybe it might move the sink a bit and break the seal against the counter top. Should I wait awhile after installing the sink to let the seal solidify?
Old 12-08-2011, 01:19 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I've always seen the disposal installed after the basin is clamped down. Who wants to wrestle the sink with the extra weight of the gd. And it will be easier to get to the tie downs w/o something else in your way.
titanoman is offline   Reply With Quote
Old 12-08-2011, 08:19 PM   #4
Rewards Points: 5,336
What type of sink are you using?
Material effects methodology.
Ron
B. Franklin 1759
(un)bending laminate countertop chenzarino Kitchen & Bath Remodeling 11 10-12-2014 10:23 AM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
questions on sealing slab , underlay pad, double padding under laminate pauls Flooring 8 02-21-2009 01:10 PM
Laminate Countertop in Bathroom Least Expense? houston Kitchen & Bath Remodeling 2 02-01-2009 12:19 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
