Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-13-2008, 09:48 PM   #1
banging thumbs
Sagging Joist - :-(
My 1950 kitchen is demo'ed and while finishing the wiring, I noticed that one of the joists is sagging. This explains the crack the length of the room before demo.
This is a single level home with no basement, just a crawl space and a crawl attic. There's a piece of wood nailed to the side of the joist where it looks like they might have tried to fix this in the past...I think you call it sistering? The joists are 2x6. FWIW, it's the 3rd one over in the photo. You can make out the support board nailed to the side.
Any suggestions on what course of action to take? The sag is about 1/2"+ on the one beam. Should we replace it or can it be cut and "sistered".
Thanks.
bakerhouse is offline   Reply With Quote
Old 05-15-2008, 09:15 AM   #2
RippySkippy's Avatar
Sagging Joist - :-(
How far out of plane is the living side?
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 05-15-2008, 09:58 AM   #3
Moderator
Termite's Avatar
Sagging Joist - :-(
Given how far you've already demolished the ceiling, this is a no-brainer. Replace that joist!!! Very easily done.
Sistering another joist to it won't take the sag out of it, but would strengthen it. I'd advise against that.
Old 05-15-2008, 11:30 AM   #4
banging thumbs
Sagging Joist - :-(
We just finished replacing it. Thanks for everyones time.
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
Floor Joist question FatAugie Building & Construction 8 02-17-2008 08:02 PM
Cutting/drilling hole in joist - How big? curls00 Carpentry 3 07-20-2007 10:56 PM
sister a joist Jack Hass Carpentry 7 06-19-2007 06:39 PM
Raise a sagging joist duder Building & Construction 5 03-09-2007 12:56 PM
