Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 07-17-2012, 10:14 AM   #1
Safe to remove this wall?
This house was new construction when I purchased it. This wall is under the stairs in my basement. The stairs are nailed to the studs, but the studs themselves have shims above the bottom plate as they were cut too short. These shims are easily removable (no weight apparent on the wall)
I would like to cut them at the bottom of the stairs to open up the storage area a bit more. The studs also provide support for the railing coming down the stairs.
Am I safe to go ahead with the removal?
Thanks in advance.
Mitch
MLayden is offline   Reply With Quote
Old 07-17-2012, 10:30 AM   #2
It looks like it's just there to install sheetrock over it at some point.
If it was mine I would remove them and install a header at the top and run double jacks on the to ends.
That way the floor is still fully supported (in the off chance it's a supporting wall) and you could put the new studs any place you want to or just leave it open.
MLayden (07-17-2012)
Old 07-17-2012, 10:40 PM   #3
The studs don't support the stair stringer, its supported at top and bottom.
The studs do support the drywall that lines the inside of the stair well! The drywall must have support. Perhaps cutting the studs off even with the underside of the stringer would suffice!
Old 07-17-2012, 10:43 PM   #4
The underside of the stairs will need to be covered with 5/8 fire code to meet code.
Old 07-17-2012, 11:25 PM   #5
Usually the floor joist beside the stairs will be doubled up.
This one is not. And it looks to be 8-110' to the wall.
That wall may not be load bearing, but I would get someone onsite to look at it.
Once before everyone said that wall was not load bearing, the guy had it checked out, it was load bearing!!!!!
mae-ling is offline   Reply With Quote
Old 07-18-2012, 04:56 AM   #6
paper hanger and painter
chrisn's Avatar
I like that advise,I don't think anyone here looking at a pic can or should make that decision.( load bearing or not)
Old 07-18-2012, 09:40 AM   #7
Coconut Pete's paella!
CoconutPete's Avatar
Is that lamp broken or does it just look like it is?
CoconutPete is offline   Reply With Quote
Old 07-18-2012, 09:51 AM   #8
I can't tell by your pics, but it appears as though that you have a straight shot run? What I mean is do those stairs go straight from the basement to the first floor, or do they go up to a platform and then turn? Also, do you have stairs that go from the first floor to the second floor right above those set of stairs? Typically for any stairwell you either have a bearing wall on the sides, or you have at least a doubled up floor joist, or a glulam beam. Without seeing a few more photos looking at your whole setup it wouldn't be fair to assume that it isn't a bearing wall..
CopperClad is offline   Reply With Quote
Old 07-18-2012, 10:28 AM   #9
Pro Flooring Installer
rusty baker's Avatar
depends on local codes where they live
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
The Following 2 Users Say Thank You to rusty baker For This Useful Post:
MLayden (07-19-2012), oh'mike (07-18-2012)
Old 07-18-2012, 11:06 AM   #10
Yes they are a straight shot run. The stairs from the main to the upper are laid on top of this set. Beam sits at the base of the stairs with post right at bottom (kind of where dog is).
The plan was to cut the studs flush with the bottom of the stringer and drywall that.
Pete - Lamp is broken...joys of developing your basement when it's full of stuff...things break!
Can I remove this wall..? (Image) findlay70 Building & Construction 8 04-27-2011 06:02 PM
swap out bath wall tiles: re-tile or remove backerboard NJoytheRide Building & Construction 8 04-16-2011 08:52 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Help Me.....installing Wall Safe shaw Carpentry 7 10-01-2006 05:50 PM
