Is It Safe To Remove This Stud? - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-15-2009, 08:51 PM   #1
Is it safe to remove this stud?
I want to remove one stud from a wall to make a doorway a little wider, but I'm not 100% sure the stud isn't load bearing.
So I'm curious what the opinions here might be, and if you think I should get an engineer to look at it onsight please let me know.
Here is the top of the stud in the attic. The stud I am removing here is actually the second one from the right, the far right one ends inside the cieling right above the existing door frame.
The bottom of the stud ends here on the second floor.
The stud is paralell to all the roof joists. The part that concerns me is seen in the top picture where the stud attaches to the two 2x4s, those 2x4s span the length of the roof and make contact with large 2x8s in 3 or 4 places.
But at the same time the whole thing is paralell to the roof joists, not to mention even if I removed that there's still 3 other 2x4s to carry any load.
lofar is offline   Reply With Quote
Old 06-15-2009, 09:53 PM   #2
Registered User
Rewards Points: 5,264
Nice picture, I can count the growth rings. Could you post another one, maybe from six feet back? Be safe, G
Gary in WA is online now   Reply With Quote
Old 06-15-2009, 10:03 PM   #3
Does this work? I don't know if I can get a picture from much further back, too much stuff in the way behind me. The stud in question is the second one from the right of the group of studs bunched up there in the middle.
Old 06-16-2009, 12:03 AM   #4
Registered User
Yes, pull it. Non-bearing, thank you for the much better picture. Be safe, G
Old 06-17-2009, 12:22 AM   #5
Thanks GBAR. Stud removed, all looks good and the roof is still in one piece.
Cutting a stud on load bearing wall timw Remodeling 5 01-12-2009 02:55 PM
Plasma TV Mount problem - one of the 4 screws cannot hit a stud..... wasserkool Home Theater 4 01-05-2009 09:24 PM
pushed in lug stud on 92 Accord garya Automotive Repairs 2 11-20-2008 08:27 PM
Help Me.....installing Wall Safe shaw Carpentry 7 10-01-2006 05:50 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 09:16 AM
