Sad Window Installs - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-29-2008, 12:07 PM   #1
sad window installs
I just bought my first house in North Jersey (2 fam). I've got my hands full of repairs and what not, time is money and I want to get a renter upstairs asap. One problem that I need advice on has to do with the windows. The house has asbestos siding and new windows were installed within the past 18 months. Now when they installed the windows they just pretty much threw them in without properly sealing them. When it rains it actually leaks through the outside in through the wall around the window. I have money tied up in re-plumbing the bathroom and installing a new heating system and I'm looking to see if I can patch this up to hold me off till I re-side the house in a year or two. Any suggestions? Thanks -Ray
mynd66 is offline   Reply With Quote
Old 12-28-2008, 11:57 PM   #2
NJ Renovator
R&RRenovators's Avatar
Ray they have a product called GEOCEL comes in clear and white . You can get it in a caulk tube or qt, where you can brush it on. Where in North Jersey. You can get the product a store called Norge Building Supply in Paterson, NJ .
R&RRenovators is offline   Reply With Quote
Old 12-29-2008, 12:44 AM   #3
Tom Struble's Avatar
Rewards Points: 2,002
norge is on union blvd in totowa n.j.
Tom Struble is offline   Reply With Quote
Old 12-29-2008, 12:46 AM   #4
what kind of windows? replacements? new construction?
where are they leaking? water? air?
Old 12-29-2008, 01:04 AM   #5
Thanks guys for replying. This was a while ago when I created this topic, since then I used outdoor window and door sealant/caulk from home depot. It stopped the leaks I had. I am eventually going to reside this house but this should hold me off till then. You can bet I'll be back to get some tips on siding! Thanks again. -Ray
Old 12-29-2008, 08:42 AM   #6
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Glad it's under control for now. You'd better bookmark this page for reference. http://www.albertsroofing.com/Window%20Flashing.htm
tinner666 is offline   Reply With Quote
Old 12-29-2008, 06:28 PM   #7
fhi vinyl windows
fhivinylwindows's Avatar
Rewards Points: 150
Good link, I bookmarked it for my own use!
fhivinylwindows is offline   Reply With Quote
Window Install? sod Building & Construction 3 10-26-2008 08:02 AM
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 11:00 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 11:47 AM
Shower in Window jchri66 Remodeling 1 05-27-2008 01:50 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
