Rust Reformer - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-16-2009, 09:18 PM   #1
Rust reformer
I've got a couple old steel windows that have been exposed to the weather and I'm trying to get them to at least a decent shape. I need to do something about the rust before priming and painting. I came across this stuff from Rustoleum but don't know anyone who has used it.
Has anyone here used it? How did it do?
Thanks for any replies.
kirkpala is offline   Reply With Quote
Old 07-17-2009, 05:57 AM   #2
Never used it, but they have been in the rust control business for a long time. Probably works.
Old 07-17-2009, 07:11 PM   #3
My experience with typical products has been good. Wire brush to remove as much loose stuff as possible. The apply liberally. When it turns black the rust is converted into a non staining condition.
PLAIN O TX is offline   Reply With Quote
Old 08-13-2009, 08:46 PM   #4
follow up
It's been a while since I made the first post, but thought I'd add a follow-up note for anyone else that might be interested. I didn't know this type of product was so readily available so maybe someone else will find this helpful.
I found this in the automotive section at Stuff-mart. It was fairly inexpensive so I thought I'd go ahead and give it a try. They had other brands so I don't know how it compared to others, but I was very satisfied. I just used a wire brush to get rid of the loose stuff, like Plain O TX said, then applied it with a disposable chip brush. You don't have to worry about brush marks or anything like that, but you wouldn't want to leave large runs big globs of it accumulating. It really does convert the rust into a black surface that is ready for painting or can be just left like that.
Instructions recommended a second application if it was going to be left unfinished. It would have looked ok, but I decided on a little black spray paint to finish it off a little better. (I was going to paint it black anyway)
Ended up being a much easier task than I expected.
Old 08-13-2009, 11:56 PM   #5
Renovation Contractor
Paragon's Avatar
Rewards Points: 150
Kirkpala thank you so much for your follow up nice to hear the end result for a change!
James D. Van Raden
Owner, Paragon Renovations Moorhead, MN/ Fargo, ND
"Committed to providing the finest renovation services available"
Paragon is offline   Reply With Quote
Rust stain on roof krtw Roofing/Siding 15 10-24-2015 05:17 PM
Rust on Grille of Outside Condenser Unit (photos) Carol2 HVAC 2 06-01-2009 04:02 PM
Rust on Bath Tub About to Be Refinished jonathan03 Remodeling 5 02-13-2009 05:20 AM
bathroom sink rust removal? bofusmosby Plumbing 4 11-12-2008 06:28 PM
fertilizer fleecing? Wisco Landscaping & Lawn Care 3 08-24-2008 06:14 AM
