Running CATV Cable - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-26-2007, 09:25 PM   #1
Rewards Points: 77
Running CATV cable
I've been having trouble with my CATV service, and today the cable guy came out and replaced the cable leading from the box on the outside of the house to the main splitter in the attic. He did this by tacking cable up the brick wall, to the soffits, and finally through a soffit vent; he didn't tell me he was doing this, and I discovered it hours after he left. This house being only three months old, I'm kinda ticked about this, as all the external wiring was previously hidden, and now it's already on its way to looking like the 50 year old rental I moved from. I think he should've spent a little more time on the job and fished it through the wall so it wouldn't show, and I plan on calling the cable company and asking them to come out and do it right. What do you suppose my chances are that they will? (Put another way, am I being unreasonable?)
tima2381 is offline   Reply With Quote
Old 03-26-2007, 09:30 PM   #2
Rewards Points: 6,652
CATV installers are paid to correct the problem, not being electricians. Since he did what was on the work order, and nothing more, it is up to the home owner to correct. If anything, it is a simple fix if there was the ability to pull the wire where the old wire is, but due to it is a finished structure, you have the choice of pulling new wire from the attic to the box, and calling the CableCo to charge you for a termination call (in other words, crimp new connectors), or painting the wire to blend it into the structure.
Old 03-26-2007, 09:39 PM   #3
yummy mummy's Avatar
Rewards Points: 1,016
I think we pay enough for cable, and the company should come back and do the job to your satisfaction, or threaten to go to the media, and then you see how fast they will correct it.
yummy mummy is offline   Reply With Quote
Old 03-27-2007, 10:03 AM   #4
I have a friend who work for the Cable company, he did one time come to my home to correct the bad signal of my internet problem... he is very knowledable/skillful on testing internet signal and making connectors..etc. but when it come to laying wire and breaking walls in order to gain access, he does not give a XXX... I break the drywall...etc. he cut the wire and reconnect...etc.. finally everything is working fine... I have to do the drywalling fixing myself....
I think cable guy is not good at running wires like the way contractor does... this is not part of the job and they probably didn't equip with such equipments...etc....
KUIPORNG is offline   Reply With Quote
Old 03-27-2007, 11:17 AM   #5
Rewards Points: 77
Thanks all for your comments. The cable guy did say something about "bad pre-wiring" so that may be something else to look into, as a new home warranty is in effect. On the other hand, cable (and telephone) techs do fish wire when installing new outlets. Is fixing my problem really that different? I think he would have to drill through brick, and the wall is insulated, but that's all I can think of. All he needs to do is feed < 10' of cable down a wall to the exterior.
In-Floor Heating Cable Trouble... sootybuttercup Electrical 24 12-18-2014 09:01 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
Running New Coax modena Home Theater 3 07-18-2007 02:18 AM
Coax cable removal or disconnect RobbC2 Electrical 3 04-14-2007 08:21 PM
running ethernet through attic null_pointer_us Building & Construction 3 05-15-2006 06:08 PM
