Rough Opening Too Small For Standard Sized Entry Door... - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 06:29 PM   #1
Rewards Points: 272
Rough opening too small for standard sized entry door...
I have an entry door I want to replace and the rough opening is 81.25" tall. I haven't found an off the shelf door yet that fits in a rough opening less than 82". Talking to a window/door company in town they would have to order one to fit and that would involve cutting it down and voiding the manufacturers warranty I'm not too crazy about that idea. Charging me an extra hundred dollars for the cutting and then not giving me a warranty.
I wondered about actually cutting the header. Suspect it would need close to 1" cut off. Will I lose all integrity in the header or will taking 1" off still leave me with enough strength? This is an older house and I'm assuming it was built with a standard header.
We are talking about a pretty standard $480 fiberglass door and not some multi-thousand dollar mahogony entry system.
What should I do?
speedster1 is offline   Reply With Quote
Old 10-04-2010, 07:04 PM   #2
How big is the header ?
How wide is the door ?
Is it in a gable wall...or one that the ceiling joist land on ?
Old 10-04-2010, 08:05 PM   #3
Rewards Points: 272
*the door is 36" wide and is on the gable end of the house. i do not know how thick the header is without actually tearing into the wall. i hate to do that until im ready to install a door.
Old 10-04-2010, 10:27 PM   #4
Registered User
Rewards Points: 4,902
An outside picture would be nice from about 20' away. (include the roof line)
Gary
Old 10-04-2010, 11:43 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
Since this door is in a gable wall I won't tell you what to do but if it were mine I would cut the 1 inch out and go on with it.
Most times there are two ears sticking up on top of the door jamb that can be cut off and sometimes that will be just enough to let it fit.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 10-05-2010, 12:02 PM   #6
Rewards Points: 358
I had the EXACT same problem. Took a plainer to the top and bottom of the door frame (the actual door frame, not the rough opening) and took a little off, worked great
cbzdel is offline   Reply With Quote
Old 10-12-2010, 01:17 PM   #7
Rewards Points: 2,630
I am with CBZDEL. Should be able to take 1/2" from top and bottom of a standard door.
If you really want to buy it finished, though, I think you just need to get a couple more prices. An extra charge for a non-standard size door is understandable. But anybody who tells you it won't be under warranty is a joker that you shouldn't be dealing with anyways.
SPS-1 is offline   Reply With Quote
Old 10-12-2010, 06:22 PM   #8
Not so new
12penny's Avatar
Rewards Points: 520
On a fiberglass door?
12penny is offline   Reply With Quote
Old 10-12-2010, 08:38 PM   #9
Never tried that on a fiberglass door. But it doesn't have to be fiberglass, does it ?
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 08:22 AM
HELP -- Entry front door suggestion Ddebal General DIY Discussions 2 09-01-2009 08:08 AM
Problem with garage door side entry thundercloud Carpentry 6 06-09-2009 07:27 AM
Rough opening for door is 1/4" too small-what to do? Badfish740 Building & Construction 15 02-08-2009 11:05 PM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
