Rotten Sill Plate - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-07-2011, 09:15 PM   #1
Rotten sill plate
I am about to replace the rotten bottom sill of my old home that was built in 1870. This house has true rough cut oak 2x4 boards. The width of my front house that needs replcaed is 12 ft. If I can not lift the house up, can I just build in two section a 2x4 treated 6ft long to two 2x6 treated boards standing on its side, then using a 2x4 on top of that. Do this 2 times?
chandelor74 is offline   Reply With Quote
Old 09-07-2011, 09:56 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
Could you post some pictures of the damaged area, close and from a distance?
Is your home a single story or two story? What kind of foundation do you have, what type of floor joists. Have you checked the floor joist for rot?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
replacing rotten sill plate on brick exterior home S.LaRue Remodeling 11 11-02-2011 08:50 PM
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 08:08 PM
Rotten Sill Plate Scottrik Building & Construction 10 09-13-2010 12:38 PM
rotten sill plate replacement mrad777 Carpentry 3 10-28-2008 12:19 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
