Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-16-2012, 02:32 PM   #1
Rookie Contractor Help needed! Adding a door to the garage.
Hi Guys,
I would like to replacing the existing window into a entry door.
The problem is there is a 12inch high and 8inch wide foundation at the bottom.
I wonder if I can cut the foundation off to fit-in my standard 82*30 sized door.
My main concerns is the will cutting of that 30inch wide foundation will cause
any structural damage to my house.
littlesucker is offline   Reply With Quote
Old 12-16-2012, 05:39 PM   #2
DIY Enthusiast
sublime2's Avatar
Originally Posted by littlesucker View Post
Hi Guys,
cut out the concrete in that area and be sure to put a header above the door to support that area.
Should also think about sealing the newly exposed foundation in some way.
sublime2 is offline   Reply With Quote
Old 12-17-2012, 09:56 AM   #3
Thank you Sublime2 !
I just worried if cutting will damage the surrounding foundations structurally.
Any ideas ?
Old 12-17-2012, 10:26 AM   #4
Any ideas ?
how deep does that foundation go ?
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is online now   Reply With Quote
Old 12-17-2012, 10:32 AM   #5
I don't know how deep it goes underground.
But it is 12inch above the garage floor.
Old 12-17-2012, 10:45 AM   #6
You can rent a chainsaw with a special blade the will cut right down to the slab on the sides.
If that's just block sitting on the slab once the sides are cut the block can just be knock out.
littlesucker (12-17-2012)
Old 12-17-2012, 01:08 PM   #7
I am thinking renting a diamond blade concrete saw at homedepot, will that work?
Old 12-17-2012, 01:35 PM   #8
DIY Enthusiast
sublime2's Avatar
Yup! From the pic it appears you will have room to use that type of saw.
The Following User Says Thank You to sublime2 For This Useful Post:
Old 12-17-2012, 08:54 PM   #9
go to your local building department. they probably have blue prints for the house that will show you how deep it is.
my thinking is, and perhaps is wrong. that if that foundations isn't deep enough, cutting out 12" will cause issues you don't want. just sayin.
Old 12-17-2012, 09:16 PM   #10
Home Remodeler
I would use a 36 inch door.
mikey48 is offline   Reply With Quote
Old 12-18-2012, 03:44 AM   #11
Why? It is just a side door.
Rookie Contractor Help needed! Adding a door to the garage. littlesucker Remodeling 0 12-16-2012 02:24 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-26-2011 12:58 AM
Adding onto an existing garage awayne Building & Construction 2 06-04-2006 10:16 PM
Adding garage outlet Shane Electrical 1 02-23-2006 05:43 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
