Rookie Contractor Help Needed! Adding A Door To The Garage. - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-16-2012, 02:24 PM   #1
Rookie Contractor Help needed! Adding a door to the garage.
Hi Guys,
I would like to replacing the existing window into a entry door.
The problem is there is a 12inch high and 8inch wide foundation at the bottom.
I wonder if I can cut the foundation off to fit-in my standard 82*30 sized door.
My main concerns is the will cutting of that 30inch wide foundation will cause
any structural damage to my house.
Rookie Contractor Help needed! Adding a door to the garage.-2012-12-16-252010.46.30.jpg   Rookie Contractor Help needed! Adding a door to the garage.-2012-12-16-252010.02.58.jpg
littlesucker is offline   Reply With Quote
Adding Microlam to garage, to support 2 doors and storage??? Shannon Building & Construction 8 10-20-2011 12:58 AM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-26-2011 12:58 AM
Adding onto an existing garage awayne Building & Construction 2 06-04-2006 10:16 PM
Adding garage outlet Shane Electrical 1 02-23-2006 05:43 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
