Roofing Tar On Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-16-2010, 10:08 AM   #1
Roofing Tar on Wall
How can I remove black roofing tar from a painted wall?
bbowley is offline   Reply With Quote
Old 08-16-2010, 11:34 AM   #2
Perhaps something like acetone or a commercial product like Goof Off would work for your tar removal? However, you'll probably end up having to touch-up the paint a bit too.
H8Mondays is offline   Reply With Quote
The Following User Says Thank You to H8Mondays For This Useful Post:
bbowley (08-16-2010)
Old 08-16-2010, 12:28 PM   #3
Rewards Points: 5,336
Depending on how wide spread it is, it might be easier to dig it out, patch the wall and paint. Smeared tar will bleed through paint. I don't know if the stain killer primers will hold it back.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Old 08-16-2010, 02:43 PM   #4
I will try that. I don't mind having to repaint the room as it is small. Patched a roof and did not know that there was a small opening and some of the tar leaked through and down an inside wall at a corner.
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 04:33 PM
Cutting through masonry wall mwpiper Remodeling 4 04-17-2010 10:30 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 05:28 AM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
