Roller Wheels For Sliding Doors - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 06:19 PM   #1
Rewards Points: 528
I just installed new roller wheels for a double pane sliding door from "Pella". The old wheels needed weekly adjustment; so they were replaced. I can see that the thread on the adjustment screws was showing signs of wear. But now the new wheels after only one week, need to be adjusted. When the door was new, it did not need adjustment this soon.
Any ideas on what is wrong? If the wheels had a locking screw, then I would not have this problem. There is a square nut that may have move out of place but I would need to remove the door and pull out the roller wheels to check.
rjordan392 is offline   Reply With Quote
Old 07-06-2010, 06:21 AM   #2
There is usually a nylon or plastic 'nut' to keep the screw from moving easily(friction fit). It may have fallen off or broken. The only way I know of to ckeck or fix to remove the door.
Old 07-06-2010, 08:50 AM   #3
Rewards Points: 528
I will do a better check of the assembly after this heat wave is over. In philly, it is going up to 102 today.
Old 07-06-2010, 08:23 PM   #4
Rewards Points: 5,336
Why not go to the air conditioned Pella store and look at the display?
Ron
Input on which doors to replace interior & exterior door with... tomas21 Carpentry 13 12-08-2009 09:32 AM
Interior door swelling? jdeters79 Remodeling 9 08-15-2009 10:51 AM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 01:37 PM
UGH! A lesson for new Pre-Hung Doors javan General DIY Discussions 6 08-08-2008 07:47 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 05:04 PM
